Question about Gigabyte GA-7VKML Motherboard
Compaq GA-7VKMLProblem with the Gigabyte GA-7VKML Motherboard
    New Friend:
Vga card problum
Posted on May 24, 2013
PCTServices
  • 120 Answers
SOURCE: Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Posted on Oct 02, 2007
cpenzes
  • 1102 Answers
SOURCE: Compatable gigabyte ga 81915pm motherboard
you may not have to format
you should be okay
are you sure power supply is not going
remove cd drive and boot see if you can get to safemode
Are you sure you have'nt had pc opened and maybe loosened a memory
I still don't think it's the motherboard.I would go more for a memory or power supply problem
let me know
Posted on Feb 13, 2009
rasengan79
  • 138 Answers
SOURCE: gigabyte ga-8i915pm
You can download the manual here
Posted on Sep 27, 2009
nyilasrobert
  • 627 Answers
SOURCE: Can Gigabyte GA-8I945PLGE-RH supports 4gb ram?
Sorry, but at the moment you can't do that. This is because the BIOS is programmed to manage only 2GB memory. I searched for BIOS upgrade to resolve the memory issue but with no luck. At the moment your motherboard supports only 2 GB RAM.
Posted on Sep 30, 2009
ed_coyle
  • 91 Answers
SOURCE: gigabyte ga-81915 pmd motherboard/precott 3.6 cpu/upgrade cpu?
the best and cheapest up grade is RAM.
Make sure you have all the memory your machine can handle.
A quick look say it can handle Core™ 2 Extreme QX9770(3.2GHz,12 MB)
And it has a PCI-express slot so you have a big chiose of video cards.Are you using the machine for gaming?
Posted on Jan 10, 2010
Testimonial: "Sounds good to me. No gaming.Thanks."
System shuts down at times. May take several times to try and reboot. When I try to reinstall windows with a CD Recovery Disk, I get an error which says Bios ACPI not comliant and will not go any further....
Enter you're bios and disable ACPI. Wait until you have at least SP2 installed before enabling ACPI. While in the bios open, Hardware Monitor & MISC Setup. Watch the CPU temp. See page 53 in you're manual.
You're system shutting down may be caused by the CPU over heating. This is a safety feature for all MBs. Suggest that you remove the CPU heat-sink assembly from the CPU. Check the thermal past / tap. If it is dried or cracked replace. Remove the old using house hold alcohol on a clean rag. (Not dripping wet). At this point there is no need to remove the CPU. Clean the CPU's fan and blow out any dust build-up within the assembly. The heat build up will cause you're system from booting untill the CPU cools. This is why it seems to take awhile for you're system to boot.
Link to Gigabyte GA-7VKML manual; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_7vkml_e.pdf
Gigabytes main site for GA-74KML;
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1306
Cheers'
Mike
Feb 06, 2010 | Gigabyte GA-7VKML Motherboard
Broken gigabyte ga-7vkml cd
download the drivers from a cyber cafe or a freind's house from this link
http://www.giga-byte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1306
use a cd or a usb drive to transfer and install tha drivers on your pc their is no other solution
Jul 09, 2009 | Intel Motherboard
Drivers
compaq presario model sg1118il was have a Motherboard manufacturer's name: Gigabyte GA-8S661FXM-775
To download the VGA driver try this link
http://www.gigabyte.com.tw/Support/Motherboard/Driver_DownloadFile.aspx?FileType=Driver&FileID=840
I hope it helps!!!
Nov 17, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
BIOS
Check the Battery Connectors are ok & not rusty. Load Setup defults in BIOS. Change the date from BIOS.
Best Luck..
Jun 23, 2008 | Gigabyte GA-7VKML Motherboard
Gigabyte GA-8LD533 Motherboard driver not found
plz check the following website
http://www.gigabyte.com.tw/Support/Motherboard/Driver_List.aspx
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1402
Jun 13, 2008 | Gigabyte GA-8LD533 Motherboard
Gigabyte GA-7VKML Motherboard Logo
105 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
