Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
After converting my machine from window vista to window 7 my unit not detecting my dvd rom
    Scholar:
  • 88 Answers
Update windows through microsoft (SP1 especially)....update all drivers. Check device manager to verify no problems there. If a problem go to the pc manufacturers web and look for specific drivers for the model in question.
Posted on May 24, 2011
My daughter has a C551 NR running vista. The CD\DVD Rom stop working in Vista so I used an external CD drive to install Windows 7, works great. . I ordered a new drive upon HP recommendation 435778-001....
should recognize the cd rom /dvd unit automatically
lower picture is of the c300 cd unit
anything look different from the original ............lowest picture
CRX880A Compaq Presario C305LA C508US C551NR Optical Combo Drive CD-RW DVD- ROM
Apr 17, 2017 | Compaq Creative Sound Blaster PCI 128...
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
I have an emachines e442-v634 w/ Windows 7 Home Premium installed. I tried to remove the bottom cover when the machine stopped working with a blue error screen and, I think a cable or wire got...
I would suggest you check the BIOS if everything is detected properly. Like the hard drive and the memory. If both are working properly and being detected by BIOS properly, then you just might need to install your Windows 7 thru USB. You might need to use a different computer to convert your Win 7 OS DVD to USB installer.
1. Use a different computer w/ DVD 2. Use ISO software to convert the Win7 DVD to ISO 3. Download the converter from this link click here or directly from this link 4. Make sure you have an available USB Flash Disk that has a capacity of 4GB or higher. 5. Once you're done converting the Win7 DVD to an ISO file, use the tool above to convert the ISO file into a USB installer.
This will only work if your hard drive is properly detected. Bootmgr error means 2 things, either the hard drive is not detected or corrupted windows installation.
Hope this helps!
Sep 21, 2011 | Computers & Internet
Cannot Detect CD/DVD Drive and USB Drives
mark_holzem
If the drives are not being detected this is a sign that you need to have the drive letters mapped. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 06, 2011 | Gateway (5500381) CD-ROM Drive
Dvd not reading
The objective here is for us to determine if the dvd is bad or Operating system is causing DVD not able to detect DVD's or cds
Hardware Issue
1. Try booting the computer from the DVD. Use the windows XP or vista or windows 7 to boot with it
2. If the DVD boots up. Definitely the DVD rom is working because it can read dvds outside of windows proceed to step 4
3. If it does not boot up make sure that the dvd is working on another DVD rom. And we are sure that the dvdrom is bad and needs to be replaced
Software Issue
4. Click start -> Click Run (Windows XP)/ Start Search (Vista) / Search Programs and Files (Windows 7)
5. Type Regedit
6. Click on the triangle/plus sign beside HKEY_LOCAL_ MACHINE
7. Click on the triangle/plus sign beside SYSTEM
8.Click on the triangle/plus sign beside CurrentControlSet
9.Click on the triangle/plus sign beside Class
10.Click on the Folder {4D36E965-.......}
Note: The first 4 digits might be the same we need the digit that has a 65
11. Restart the computer and your done
Jul 07, 2011 | Computers & Internet
I need solution for this problem immediately I installed windows 7 in my PC. after that in My PC DVD RW is not working.
Was the Windows 7 installed from a clean slate or you upgraded from Vista to Windows 7? If you have upgraded from Vista to Windows 7, then this is definitely a driver problem. You can try to update the driver by going to Device Manager, check if the DVD drive is listed. Pull down the drop down list, and right click on the devices listed under DVD/CD-ROM Drives and choose Update Driver Software.
If the DVD drive came with a software bundle (e.g. Nero Burning Application) Try reinstalling these application under Windows 7 Environment.
Mar 26, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
I NEED A SOFTWARE OF HITACHI DVD-ROM GD-5000 DRIVERS, BECAUSE MY EQUIPMENT THERE IS NOT IT, PLEASE, CAN SOMEONE REOLVED MY PROBLEM? thanks
Windows XP and Vista and 7 all contain "built-in" support for reading CD and DVD drives.
If your computer cannot detect your hardware, replace that "dead" CD/DVD drive.
Jan 19, 2011 | Computers & Internet
CANT FIND DEVICE DRIVER FOR SONY AD5260S,WINDOWS
The device-drivers for CD/DVD units are "built-in" to Windows XP/Vista/7.
So, you have either a "dead" drive, or some other problem (data and power connectors not connected to the drive) or some BIOS-configuration problem.
Jul 31, 2010 | Sony Computers & Internet
I installed a win 7 beta version on my pc..and when i wanted to revert it into vista again it won't install anymore to any os except win 7. When i tried to install vista it cannot detect my HDD, and when i...
To make sure you install back again your Windows Vista and Windows XP is this.
First:
  1. Go to Bios Setup and change the setting of your Hard Disk drive from Sata to IDE mode.
  2. Boot priority the CD/DVD Rom to run your Bootable CD/DVD.
This setting are quietly working, good luck!
Jul 29, 2009 | Computers & Internet
Toshiba Satellite P205D-S7479 Drivers for DVD-ROM
Download new driver files of pioneer dvd drive fron internet.
Apr 17, 2009 | Toshiba Satellite P205D-S7479 Notebook
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
