Question about Singer CG590 Mechanical Sewing Machine
On my CG 590 C Singer machine, the bobbin winder has become loose, and it sounds like there is a loose screw or something in the handwheel.
  • 3 more comments
  • bob4linda May 24, 2011
    e-Guru, thank you for your quick reply!
    However, I was not talking about the horizontal spool pin and holder at the back.
    The bobbin was being wound on the front bobbin winder, as per the directions of the manual (not while sewing!). The bobbin winder sounded different after I wound a 3rd bobbin. I cut the thread, moved the spindle left and took off the bobbin after it had finished filling and had stopped. When I clicked the hand wheel back into place, I heard a rattling noise and then noticed that the bobbin winder is not firmly attached as previously--rattling loosely not connected to anything inside the machine. The directions I was following are on p. 18 of the CG 590 Singer manual. The spindle is loose and there is something rattling inside the hand wheel.
    I look forward to your expertise once more.
    Linda
    the back.
    Linda
  • bob4linda May 25, 2011
    Hi!
    We have not heard back from Expert #1, and we hope that you can view our added comment to him and resolve our loose bobbin winder problem.
    Thank you!
    Thanks, but unfortunately, you are not describing the BOBBIN WINDER which is at the top right hand of the CG 590 C. This is nothing to do with the bobbin case which is near the presser foot, needle and holder.
    Check the diagram of parts for the CG 590 C and you will see the named part that we have a problem with.
  • 3,018 Answers
  • Lets readjust the boin case
  1. Raise presser foot and needle.
  2. Open slide plate, remove bobbin and remove needle plate.
  • Now to remove the bobin case.
  1. With a small screwdriver, turn bobbin case holder to the rear as far as it will go.
  2. Lifting the left side of the bobbin case, slide it out from machine.
  • Now to replace the bibin case.
  1. Guide forked end of bobbin case under feed .
  2. Draw rim of bobbin case under position plate . Be sure bobbin case is freely seated on hook race.
  3. Turn bobbin case holder forward as far as it will go, locking bobbin case in place.
  • Note
Turn hand wheel towards you to check to make sure it is properly replaced. Replace needle plate. Insert bobbin and close slide plate.
Regards, Tony
Posted on May 25, 2011
  • Iron
    Iron May 25, 2011
    • I see the Bobin Winder. I was not privy to any of your comment to the previous tech until after I posted the first time. I could only see the first question. I have the manual.
    • So now you have to remove the top off the sewing machine and have a look. Sounds like the shaft came loose or broke.
    • Should just be a couple of screws to remove to gain access to the top.
    Tony
  • Iron
    Iron May 25, 2011
    • Glad to be able to help.
    Regards,
    Tony
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
The main spool pin cannot be used to wind the bobbin while sewing. With this machine, you can use the supplemental spool pin to wind the bobbin while sewing using the main spool pin. There is no screw to be loose there. I am also providing the detailed bobbin diagram which will explain how the bobbin works and what are the parts which it is made of.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faqh/000000/000400/000037/faqh000437_000.html?reg=us&c=us&lang=en&prod=hf_inov4000deus
Please let me know if you stil need further explaination on the bobbin.
Thank You
Posted on May 24, 2011
I have a singer CG 590C. It didn't come with manual. I'm just learning to sew. My bobbin was hung up with thread when I pulled on it I pull the whole bobbin casing out. How do I get it back in? Help
First thing, you should probably get a manual for your machine.
Singer CG 590 Commercial Grade Manual
How to thread Singer CG 590
This machine is listed as a commercial grade professional sewing machine, so you are going to have some additional learning curve if you are just beginning to sew.
Nov 23, 2015 | Singer Sewing Machines
What should the tension be on for this machine?
Most of the time if the bobbin thread is coming through on top it means that the bobbin thread is too loose and/or the top thread is too tight and is pulling the thread too much. check and make sure that there isn't anything in the top tensioner that could be increasing the tension like lint. Good luck.
Feb 17, 2015 | Singer CG-590 Commercial Grade Sewing...
How do I adjust needle depth on my Singer 590 c?
There is an Allen screw on the shaft of the needle bar that you can loosen to be able to adjust the height of the needle. Some machines also have markings as to where the needle height needs to be. If you still have trouble talk to the people at the link below. They may be able to help. good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Nov 23, 2014 | Singer CG-590 Commercial Grade Sewing...
How to fix timing on CG 590 singer sewing machine?
It would be best to have a sewing machine technician do that; depending on your machine, it can be complicated to even to GET to the area to retime the machine.
Jul 22, 2014 | Singer Sewing Machines
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
The hand wheel just stays put while the inside of the machine seems to be moving, like something is slipping.
Move the bobbin winder to LEFT. Sounds to me like you didn't re-set after winding a bobbin.
Hope this helps!
Jimmy
Apr 06, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Singer CG-590
You can find a Users Manual plus a workbook that you can get in PDF and print. Users Manual is 44 pages and workbook is 58 pages. Go to www.mannualowl.com and search for Singer CG 590n manual. It's all free.
Apr 19, 2008 | Brother CS-8072 Computerized Sewing...
Singer CG590 Mechanical Sewing Machine Logo
358 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
