Question about Cameras
What if the images did not appear in the cam? but still in the memory card? how can i fix it?
    Sergeant:
    Champion:
  • 214 Answers
Hi Would you tell me your camera name of model and problem more detail. then I can figure it out what you have problem and solve. Thanks and vest regard!
Posted on May 24, 2011
  • hcatibod May 24, 2011
    jenoptik jd 10.0 z3 dc...the images did not appear but the files is still in the memory card..how can i fix it? thank you...
  • Myoung Song May 24, 2011
    Hi
    I am not sure about your camera model. it does not ring a bell to me. But in general I think you have taken picture in built in camera. Is that right? and you want to save?
    Please correct me if I am wrong..
    Thanks and best regard!
Old snaps some part of images will mixed in with new snap clicked
If formatting the card didn't fix it then yes I would replace the card.
Dec 26, 2012 | Sony 2GB Memory Stick PRO Duo Memory Card
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
My daughter has an Insignia NS-DSC7P09 digital camera. She had about 400 photos saved on the camera , but the last time she tried to view them, the message "no image available" appeared. When...
This is happening probably because the cam's memory card is corrupted. This is common with SD memory that has been used extensively for a long time and it's likely not caused by any fault in the camera.
You can try formatting the card (go to my computer, right click camera, click format.) but this isn't likely to work really. You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk. Hope that helped.
Apr 25, 2011 | Insignia Cameras
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
Memory stick may not work correctly
the memory stick has to be formatted with the device it is to go into or it may not recognize it
Format the stick with the camera. If this is a Web cam then format the disk in Windows with a SD memory card adapter. Can be found on Ebay for small price
Apr 19, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
How do i save pictures to my media card?
Go to manufacturer's website. Find cam and dowload manual in pdf form (it should be free). The digital cams I've had always save the pic to the card instantly. The cam may automatically be set to save to the internal memory.
Jun 22, 2008 | Gateway DC-M42 Digital Camera
Formatting memory stick.
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cameras Logo
82 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
