Question about Hunter Fan Company 7-day programmable thermostat
I have a Hunter 44860 programmable thermostat. In "Cool" mode, I can't program the temp. to below 76 degrees - the temp cycles back around to 95 degrees. I can manually override the thermostat to a cooler, "turn-on" temp, but isn't that why one buys a programmable thermostat, to not have to do this?
5 Suggested Answers
SOURCE: Instruction Manual for Model 44860 Hunter Thermostat
Well, I consulted with Randell (my 12 year old grandson) - he assisted me in finding the solution in converting cooling to heating on the touch pad. Jameson (the 4 year old grandson) looked on, wanted to help Pa-Pa - but, we could only listen to his demands to help.
I still need an instruction manual - can you advise me how to obtain a replacement (or print one from the internet)?
Your response will be greatly appreciated.
Regards,
J. Alan Overton, Sr.
Posted on Nov 19, 2008
SOURCE: heat won't come on, but
Look at your igniter on the furnace.
Posted on Jan 05, 2009
kachbibi1
  • 979 Answers
SOURCE: I set temp to 74 and stop at 70 and decresing.
The only thing I can think of other than being just old and worn out is that by design it may not be set to run but so much at a time. Has this always done this since you have had it? It may be needing calibration. One thing you can try is to set it at 2 degrees higher than you want it and then it would shut off at the temp you actually want.
Posted on Mar 04, 2009
VtToolMan
  • 704 Answers
SOURCE: thermostat takes too long to cool down 1 degree
Thermostats don't cool or heat. They are just the control device that tells the furnance or AC to operate and register the present temperature and tell the furnance or A/C to shut off, once the desired temperature has been reached.
Most programmable thermostats will take at least 1-2 weeks to "learn" how long to run the furnance or A/C in order to reach the desired temperatures you've programmed into it, for the time you want it be that temperature. Variables such as extremely hot days and higher humidity will also affect your cooling system.
Give it a little time to self-learn and it should adjust itself after a week or two of operation. You might want to take some time to review and familiarize yourself with the owners manual to see what Hunter advises for setting up and using the thermostat.
You may need to have your A/C checked to see if you're running low on freon, or need to have the coils cleaned, need to change the air filter, etc.
Hope this helps and best regards!
Posted on Aug 01, 2009
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
Auto recovery mode raises the temperature above
Hummm... how far is your Thermostat from your heater? I am reading your extensive manual but there is no mention of that distance? There was a early mention of batteries? Are yours fresh?
Is this a 'new' problem? Has it worked properly before?
Then there is this from the manual:
The installer can set SYSTEM functions once the thermostat is installed. The
default settings are shown in bold in the following list. Options are listed inside the
parentheses. Example: the default SYSTEM TYPE is CONVENTIONAL with (HEAT PUMP) as a second option. See pages 28-29 to change these settings.
Have you tried resetting your Thermostat?? Sometimes these basic 'onboard' computers get confused... especially true with lots of 'options'...
It's a little hassle to get a DIGITAL copy of your manual (I am not a Robot ~ etc) ~ but here it is:
Download manual
TROUBLESHOOTING begins at Page 68
Anthony
Dec 22, 2017 | Hunter Fan Company 5/1/1 Programmable...
Message: "in recovery"
the "in recovery mode" is refering to a thing called energy recovery management its one of the features on your tstat what it does- when you are using the program on your tstat the "in recovery" starts your unit early so if the tstat is set to be 70 degrees at 8 in the morning when 8 o clock hits it will already be 70 degrees in your house you can turn this feature off if you want in the installation setup codes
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Mar 04, 2009 | Hunter Fan Company 7-day programmable...
Trouble with newly installed thermostat
did you program your own temps, if not i believe this is part of default program!
Jun 30, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter thermostat 44860
Here is a link to the Hunter website.
If you need further assistance, please let me know.
Apr 22, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 7-day programmable thermostat Logo
155 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
