Question about Dishwashers
Water boss water softener error e3 - Dishwashers
3 Suggested Answers
  • 736 Answers
SOURCE: Water is not heating in dishwasher
the E3 error message tells you what you already know ..the water temp is not reaching its intended value ... that could be a bad temp sensor or the trouble could be the heating element itself or the electronics that power it ... the heating element can be tested with an ohm meter .. it should have low resistance (not open) ... if its good then i would suspect the electronic module that controls it or the heat sensor unit .. .. sure sounds like a design problem to me .. since there are a lot of these machine with the same trouble .. the factory seems to be having trouble fixing them .. they often give up and offer a new machine at a reduced price ..
Posted on Aug 18, 2009
Testimonial: "Thank you for quick reply."
  • 5 Answers
On the BDW13 Baumatic dishwasher I had the same problem, as I fix gas boilers I ohm tested the heating element, which was ok, I then tipped the machine on its side and took the bottom off, be careful, always disconnect the electric and water, underneath there are two thermostats, I know them as thermistors on a boiler, they screw into the brackets that hold the element in place inside the dishwasher, I unscrewed them after removing the wire connectors(pull off) I then ohm tested them and found one was an open circuit(faulty) the problem is, the one that was faulty is a non-self-resetting type, which means it has to be replaced once it has tripped, which is a real pain, the other one resets after it has cooled down.
Posted on Sep 20, 2009
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
My dishwasher gives an E3 error
The E3 error code is not a defined error for this dishwasher. If you are sure it is E3 then best option is to give the controller a reset. This is done by
Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
Press OFF at this stage. Do not attempt to run the inspection as this could damage the dishwasher unless you are familiar with the what each mode does.
If the Error E3 keeps coming back then call the Samsung technician.
Apr 15, 2014 | Samsung DMR57LF Builtin Dishwasher
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible.
Refer this site for 60 inch dishwasher and this site for 45 inch ones.
Jan 02, 2013 | Smeg Dishwashers
Bosh tankles heater error.code e3
Copy following link for EXAMPLE E3 error code troubleshoot, to gather information to 'assist tech support in determining cause and solution to problem.'
http://waterheatertimer.org/pdf/Bosch_A3-E3_Error_Code_Troubleshooting.pdf
Contact Bosch 800-283-3787, or service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Sep 29, 2012 | Bosch & Tankless Water Heater
Error message E3 on my Kenmore Elite Dryer
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Jun 23, 2008 | Washing Machines
Hobart lx30 E3 error
Error Code E3 relates to a problem with the fill. Specifically that the water level has not been recognized at the middle water sensor. This can be caused by a problem with the drain system as you describe, or by low water pressure to the machine (should be 15-25psi flow), or bad wire connection to this middle sensor.
Check for proper water pressure first (should be a gauge on the machine) during the fill. Then check / repair drain as needed. These will probably eliminate the problem
Jun 19, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
192 people viewed this question
Top Dishwashers Experts
