Question about Kenwood Sirius KDC-MP425 CD Player
My desk works great, expect the screen blink when the units button are pressed. This happens on probably every other button use or so. I think the faceplate is slight loose. While the screen flickers, it does not interrupt audio. Are there any quick and cheap fixes to stop this problem?
    Problem Solver:
  • 11 Answers
It sounds like the contacts are getting weak or the contacts are dirty... Take off the face and clean the contacts with alcohol. If that dosen't help then take a paper clip and gently bend the pins up. Be careful not to break the pins.
Posted on May 24, 2011
I have had the Magellan Mastro laying on my desk for about a month without being charged. When I now pluged in the charger nothing happens. The screen stays dark.
Try doing a master reset on the unit. It should have a hole marked "Reset". Use a blunt toothpick or end of large paperclip, pressing in on the small button inside for about 10 seconds. It should come back to life. You may see a flash of text on the screen. If so, release the button. It would probably be best to leave power hooked up while doing this, in case the battery has not taken a good charge. Thanks, Bill.
Sep 02, 2010 | Magellan Maestro 3200 GPS
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Laptop won't start up
Hi, the problem of which they power on both led and on having pressed the button of power on does not spend anything, it indicates that his equipment does not ignite and probable mas is that mother has got damaged the card reason for which it does not ignite the equipment.
Jan 07, 2009 | Toshiba Satellite A15-S127 Notebook
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
I have a gateway m-6755 series laptop/notebook power issues
first press & hold power button for 6 second then again press power button to boot...
Dec 01, 2008 | Gateway M-6755 Notebook
Inverted Screen (Upside Down)
SOME UNITS USUALLY DO HAVE A MENU FUNCTION TO FLIP THE SCREEN , HOWEVER IF THE UNIT HAS BEEN WORKING THIS WAY FOR A WHILE THEN IT MAY BE A SIGN THE UNIT IS REACHING ITS LIFE EXPECTANCY, IF REMOVING THE POWER DOESN'T WORK IT'S INTERNAL.
Aug 02, 2008 | Eiger Vision AV-710H Car Monitor
Red then green blinking lights.
push power on at button (no need to hold button)and press proceed button for 2 secounds at the same time you turn on power and it should reset.
Dec 24, 2007 | NEC PlasmaSync 50MP1 50 in. Television
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenwood Sirius KDC-MP425 CD Player Logo
37 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
