Question about Sony HVR-A1U Camcorder
"W", "T" and "R" (small)
  • Sony Master
  • 17,970 Answers
Sound like a problem with the internal pad; this job isn't easy to solve it self; I suggest contact your techincian support.
Posted on May 24, 2011
PC twin shock gamepad
Switch your gamepad to 'analog' mode by pressing small button 'MODE' at the center. Light under that button should turn red (indicating analogue mode) from green (indicating digital mode).
Nov 14, 2012 | Microsoft Xbox 360 Wireless Controller
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Tip
How to change the mouse sensitivity
<p>Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.<br /> <p><br /> <p>Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.<br /> <p><br /> <p>Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."<br /> <p><br /> <p>Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.<br /> <p><br /> <p>Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.<br /> <p><br /> <p>Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.<br />
on Dec 07, 2010 | Computers & Internet
Aspect Ratio Issue
Is the function mentioned in the manual 'optional'?
Aug 25, 2012 | LG RZ-20LA70 20 in. LCD Television
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
Left deck doesn't "play" anymore.
There is a mechanism problem in the Pinch Roller part of the deck.
It needs to be looked at by a Technician to correct.
Feb 24, 2011 | Tascam 302 PRO DUAL CASSETTE DECK Single...
I own an olevia lt42hvi; I need to change the picture (brightness, etc...) but it says I can only do it in "user mode." have never seen this before. I need help identifying and getting the tv...
I have a Olevia 532-b12 and it may be similar. Hit the small round menu button on the remote. A pinwheel shape should appear on the upper left part of the screen. Use the up/down and left/right direction keys to find picture, and you should be able to adjust brightness, contract, etc.
Feb 06, 2011 | Olevia LT42HVi 42 in. LCD Television
Hello, my monitor (philips 170S) is going in "AGING . . ." when i turn ofg the pc..when its open the monitor keeps switching off and on constantly..none of the front panel buttons works while...
Open the monitor and chek with multimeter all buttons on the small PCB. (Front pannel buttons). On my Philips 170S the seccond button from left to right was defekt. Change the button and enjoy.
Jan 02, 2011 | Computers & Internet
MP-GT1 ERROR 50
Same thing happened to me.
The thing wouldn't power on or I'd get a "DEVICE ERROR" message on the LCD.
When I pushed the level button on the left side of the unit along with the power button the unit turns on.
I have no idea what the problem is.
Oct 10, 2009 | Tascam MP-GT1 MP3 Player
Everything is working properly but cannot see anything from lcd or view finder
Hello. First thing...is there *any* display at all such as a number code in the upper right hand corner of the lcd? It will appear as "C:00:00" or "E:00:00", minus the quotation marks. If there is a "C" in front of the numbers, the problem is fixable by you--an "E" means that the problem has to be addressed by a tech. Next, to reset ALL functions back to factory defaults, open the LCD display on the side and locate the small reset button just to the left of the MENU button. Use a pen or pencil (the end of a paper clip works beautifully) and press the button momentarily. Don't use a lot of force to do it--not needed. If this doesn't bring up any display, then there is an internal circuit problem.
Can you see an image if you play back a tape? If so, then the problem concerns the CCD chip or associated circuitry. The ccd chip provides all the video information to the eyepiece and lcd screen in *record* mode. In *playback* mode, the camera acts just like a small VCR. Any video is being pulled from magnetic tape.
Is the camera still under any type of warranty? A CCD chip problem is a major repair and will be relatively costly. Do not repair the camera through a store! Find a reputable repair facility and ship it directly--the cost will be FAR less.(Retail stores take the actual repair quote, half it, and add the half to the quote *you* see.)---Hope I helped you!---Rick
Oct 01, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony HVR-A1U Camcorder Logo
18 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
