Question about Bernina BERNETTE 65 Mechanical Sewing Machine
My bernette 65 is stuck on reverse stitch. I have checked that it is not the button hole setting. I just had it serviced to get this fixed too and now its playing up again. Any ideas?
    New Friend:
Check that bobbin spin has been released
Posted on Mar 08, 2013
  • Bernina Master
  • 1,133 Answers
Take it straight back to the shop then, sounds like the fault has not been corrected.
Posted on May 24, 2011
I have a Janome Newhome 672. Cleaned and oiled it, works great. But, the decorative stitches will not form correctly. The reverse is not engaging. How can I fix this. Also, the button hole knob h
In most cases Laurie, with decorative stitches selected some machines can't sew in reverse. Your stitch length is too long or too short to make the decorative stitches sew correctly. So many things could be wrong. I'd need more info to get you going again.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Oct 22, 2014 | Janome Sewing Machines
Is there a way to do a manual buttonhole on a Bernette 65 since I so not have an automatic buttonhole foot
all sewing machines can make manual buttonholes. when the machine is adjustable stitch length, stitch width and needle position.
stitch length should be short.
stitch width to be set en route between 2 and 5 at the ends.
needle position must also be set on the way
you have to try and make some test before you get it right
good Luck ;)
Apr 27, 2014 | Sewing Machines
Husqvarna prisma 980
since the sewing machine was given to you, it might be a good idea to have the sewing machine serviced to see if there is a problem with the reverse and stitch setting.
Aug 14, 2013 | Sewing Machines
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
Bernina Bernett 55 is stuck in reverse
make sure it's not in the buttonhole setting, and if the machine
isn't in the buttonhole setting and the buttonhole lever isn't down
then it would be a good idea to have the machine checked to see
why the machine ins stuck in reverse.
Dec 13, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
My Bernette 65 is stuck in back stitch.
1 -Make sure you don't have it in the buttonhole setting.
if that don't work..
2 -Oil every thing that moves.
Jan 15, 2011 | Bernina Bernette 75
I have a Bernette 65 and when I sew, the stitch is loose and sometimes loopy on one side. The stitches are crooked on one side and the other side they are loose and the understitch is visible. What do I...
check the thread tension
check the needle to make sure it's the right one for the thread
to check the needle to if it's work with the thread
here's how to check
cut a 8 inch piece of the thread your going to use for the project, take the needle your going to use out of the machine or package, & insert the 6-8 inch thread into the eye of needle
& lift on side of the thread up to a 45 degree angle & if needle is the right size needle for the thread, it will side down the thread easily,,but if it hangs up you need a needle 1 size larger
Sep 25, 2010 | Bernina BERNETTE 65 Mechanical Sewing...
I have a very old viking - feed dog problem
The older 6XXX series are the best machines Viking ever made. But they have one flaw - if the button hole mechanism is not regularly serviced and used, it will eventually stick and the machine will only sew in reverse. This can also happen if you turn the knob backwards when in button hole mode.
I always tell my customers to make a few button holes every time they use the machine. This helps to keep the mechanism free and working between servicing.
Unfortunately the fix is not a DIY consumer project. It requires knowledge and expertise in disassembling the machine and re-aligning the parts. Expect to pay anywhere from $25 to $75 in addition to the regular servicing fee.
Steve P
Minneapolis
aka "The Bobbin Doctor"
Oct 05, 2008 | Husqvarna Viking 1
Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
Sep 01, 2008 | Bernina Bernette Deco 600
Bernina BERNETTE 65 Mechanical Sewing Machine Logo
412 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
