Question about Refrigerators
There seems to be a blockage in the drain and every few weeks it ices up trapping the fan blades. Is this a common problem with this model and what can we do to resolve it?
    President:
  • 670 Answers
Don't know what make or model of fridge that you have since you did not supply it. Assuming that yours is a frost free model, the problem is that the defrost circuit has failed causing the evap coil to ice up. Typical problems are that the defrost heater has failed or if yours is an older model, the defrost timer has stopped advancing causing the heater not to turn on. Call a service company and tell them that you suspect that you think the problem is with the defrost and they should be able to help you.
Posted on May 24, 2011
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Uline ice maker will not drain water unless I blow through the drain tube. It will drain everytime without the tube
It is air locked you need to make sure you did not double trap it and water line is not running up hill. i take it that your model dose not have a water pump on it.
Apr 07, 2013 | U-Line Icemaker
Amana freezer on the bottom is building ice on bottom of freezer ever week or so any help?
Unless your freezer is showing ice from the defrost condensate water freezing because of a defrost drain blockage I would believe your freezer is not defrosting properly. You did not mention temperature changes so here I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Now if this is a defrost problem I would reccomend that you have a look at the=> 67001036 Defrost TimerI will let you know how to test the defrost by turning the above defrost timer slowly clockwise until compressor and fans stop running. Here is a=> 67002135 Defrost Heater Assembly and here is the=> 12001937 Defrost Thermostat
Let me know if this problem is because of a defrost drain blockage or if the temperatures are beginning to warm inside the fresh food section and freezer section. If defrost problem the above parts will be the replacement parts. I will be here if you have any questions thanks...JT
Oct 20, 2012 | Amana ABB1927DE Bottom Freezer...
My insinkerator blades don't seem to be cutting, so I keep getting blockages in the U-bend. The motor works fine - how do I change the blades?
To my knowledge the blades are not replacable. Some things do not go down the drain well, potatoes, carrots, mostly vegetable that when mashed will set up. You can clean your blades by putting a few ice cubes down the disposal, don't do too many at a time or the ground ice will plug the screen. If you grind up potatoes or such do just a small amout and run plenty of hot water with it.
Jun 09, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
Freezer fan starts sounding like its rubbing louder and louder on a french door model 79577312600. if I unplug it clean out the food and use a hair dryer to defrost behind the inner skin at the center vent...
you are correct. it is not the fan causing your troubles.
you have water getting into the fan blade and freezing next to the blade causing the noise.
the ice maker is the most common problem. it maybe leaking behind the panels and causing water to form ice then get into the blade and make the noise.
shut the i/m off for a few days and see if this stops the noises. if so, then check the fill tube, its a plastic tube from the rear of the unit into the i/m. if it is overflowing and leaking then you might need to adjust the tube so it doesnt leak when filling into the i/m. its somewhat simple but may seem hard. just put some type of a sealant around the tube to prevent water from running out of the tube.
if this doesnt fix the problem, then you may have an i/m that needs replaced. but dont do that first. the tube is usually the problem.
Jan 08, 2010 | Refrigerators
Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Need to replace evaporator fan GE profile performance TNX model
Unfortunately, the evaporator fan has probably frozen in water trapped in the defrost drain. This seems to be a common problem with these GE bottom freezer models. You can shut it off for 12-14 hours and leave the doors open and it will thaw and drain into the freezer compartment. But you probably have food that you would need to put into another refridgerator to do this. Another option is to take out the bottom liner of the refridgerator to do this - I had a service man do it the first time it happened - he then used hot water and a hair drier to get rid of the ice that was stopping the fan. Unfortunately, it seems once this problem starts happening, it will continue to reoccur and I have not found a long term solution yet
Nov 15, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Iced up Samsung RS21 JGNS Help!!
Defrost the unit and after defrosting, with the unit unplug rotate the fan blade manually using your finger. The fan should rotate freely, the blade should not touch the fan frame. Slow rotation of fan motor can cause icing. Worn out bearing, misalign fan blade, partially burn fan motor can slow the rotation of blower motor.But if the blower operate normally, then the unit may be under charge of refrigerant. Qualified technician is needed with this problem.
Mar 05, 2008 | Refrigerators
GE Bottom refrigerator/MOdel GS18LCRABB
I can only wonder if the drain tube has been cleaned out to make sure water flows into the pan .Also make sure it is fully defrosted and left over water will freeze quick.
Eeggman
Feb 18, 2008 | GE GDS20KBS Bottom Freezer Refrigerator
Bottom of freezer icing with thick sheet of ice
you have a froen drain thats why it is allways getting ice on the floor. you need to remove as much as you can then remove the back of the freezer so you can clear the drain pan and clear the drain. its not hard to do just you will have a lot of water on the bottom and your floor maybe. once you remove the ice from the pan have some very hot water and pour it in the pan utill the drain is free and the water go's down into the drip pan. shut the unit off untill tour done and be carefull around the coils. once its clear put the back on and plug the fridge back in. you will now have no more ice build up. make sure there is no food back there that can block the drain either. its a god time to clean the freezer out
Aug 10, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
