Question about Carrier YCB213D Air Conditioner
Where can I purchase a condenser fan for my ycb213d room air conditioner
4 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Air conditioner fan problem
Take a brush and clean it, then oil it.
Posted on Jun 02, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: My room air conditioner fan blower doesn't work
The most likely cause is that the fan itself is defective.
Posted on Nov 28, 2009
shastalaker7
  • 1515 Answers
SOURCE: We require condenser fan motors for Interclisa
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Posted on Jan 22, 2010
Carrier YCB213D fan blows no cooling
Usually happens when the unit is low on gas, get it serviced by a trained person
Aug 04, 2014 | Heating & Cooling
Brand new kenmore air conditioner 18500 btu, there is no place for the water to drain, no drain plug? water is getting high... model 70181
The new Room A/C's do not have drains as it uses the condisation from the pan to help cool the coils this makes the unit more effecient.
Sep 01, 2011 | Kenmore Room Air Conditioner
Hi - I have a MR SLIM MSZ A09NA HEAT PUMP. It is dripping inside the room. It was installed in 2008. Is seams to be loose on the wall. Is it supposed to be level? tipped to the right ?
An air conditioner should be installed so it's level. These appliances are designed so that condensate collects below the fan and runs into the slinger ring, which is made of sheetmetal and is part of the fan assembly. The bottom of the ring acts like a gutter to collect condensate. The fan then picks the water out of the ring and slings it against the condenser coils.
Recycling the condensate in this manner increases the coils' cooling capacity. Check the air conditioner for level -- front to back and side to side -- when you install the unit.
If it is tipped a little to the Front then you will Get water inside room.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Compressor will not stay on no matter the temp. setting. After running a couple of minutes the unit emits a scraping or buzzing noise and compressor goes off.
Sounds like you lost one of your fans if air is circulating in the room its the condenser fan. Thats what blows across the condenser coil to the outside. It may just be a capacitor thats what helps the fan get started but usually if the fan is popping capacitors there is something wrong with the fan but at the same time capacitors do just go bad. hope this helps let me know.
Jul 23, 2011 | Frigidaire FAH126S2T Thru-Wall/Window Air...
MY GE ROOM AIR CONDITIONER AGH08AJG1 SWITCH BETWEEN COOL AND FAN EVERY 5 MINUTES APROXIMATELY NEVER SATYS COOLING UNTIL THE DESIRED TEMPERATURE IS REACHED
Check and clean the filter if found to be dirty. It is usually behind a decorative panel below the cold air output grates (when the cold air is on the top front).
The filter is behind the large, rectangular, slotted front panel. The evaporator coil is behind the filter. The fan behind the evaporator pulls the room air through the filter and evaporator coil where it is cooled and dehumidified. It is then discharged through the grates on the top of the front.
Direct the airflow from the unit up and away or left / right to prevent the cool air from being drawn in the front of the unit (this is where the thermostat sensor is located). Use the highest fan speed to help force the air away from the intake, too. Inspect the condenser and evaporator coils (condenser is outside and evaporator is directly behind the filter. Clean if dirty or icing over. Be sure to install a filter if none was present. There are products made specifically for cleaning between the fins of the condenser and evaporator coils. Use them only as directed.
If these suggestions do not work, you may have a problem with the thermostat, refrigerant level, condenser or condenser fan.
Jun 22, 2011 | Heating & Cooling
Tell me Electrolux spit Air conditioner fan part name its fit of out side of room window.
It is condenser fan. The motor has all info stamped on it.<br /> Call <a href="http://www.marcone.com">www.marcone.com</a> with your mod number<br /> <br /> If this was helpful please rate me.<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a>
Aug 26, 2010 | Electrolux E23CS75SS Air Conditioner
Fan Coil Unit is Cycling on and off. But the room is still hot.
Check electrical connection at the T'stat and the indoor blower . Sounds like a loose connection.
Sep 11, 2009 | Cfm Daikin R410a Split System Air...
Need btu rating ???
Carrier YCB213D Y Series Window Air Conditioner 21000 BTU 230/208V. No Remote Control. High-efficiency energy-saving units. Quiet cooling for living areas.
Please dont forget to rate ;o)
Aug 17, 2009 | Carrier YCB213D Air Conditioner
Fan blows but compressor does not run.
turn off asap! the compressor is the heart of your system, so it might need a hard start it gives it more power if that does not work be ready to pay for a new outside part
Oct 16, 2008 | Carrier YCB213D Air Conditioner
Carrier YCB213D Air Conditioner Logo
18 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
