Hp 1050c designjet plus.I changed my black printer head and plotted 3 drawings plotted fine but I ran out of black ink. I proceeded to install a new #80 black ink cartridge, no error messages showed up but when I went to plot black ink spilled everywere onto the paper can you help me identify the problem??
    Genius:
  • 1,089 Answers
Call HP, their cartridges are guaranteed. There is no reason why a new cartridge should dump ink like that.
Posted on May 24, 2011
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
Error-check printhead path 2
After plot one ploter going to print head check mode on dsj 1050.
May 17, 2010 | HP DesignJet 1050c plus InkJet Printer
Error code 04C300 001E0000
This is an IO error. If there is a Hard Disk installed, remove it - the printer will run fine without it. If that does not solve the problem, remove the JetDirect card and run the test print. If the test print works, replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Nov 19, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
Scaling drawings automatically HP8100
Check the printer settings and make sure to set the "Fit To Page" option to "None".
Jan 15, 2009 | HP DesignJet 1050c plus InkJet Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
HP 1050c adds small amount to each plot
i have seen this problem before. if this is the same problem? have you used this printer and autocad before ? i mean without error? if this is the same problem, we never could get autocad to work properly and had to replace the DJ1055CM printer with a T1100. hope this helps you.
Oct 06, 2008 | HP DesignJet 1050c plus InkJet Printer
127 people viewed this question
jasbo
jasbo
