Question about Sansui D 27" TV275 TV
How to chance channels from one number to another. which key much we must use in remote
  • Sansui Master
  • 6,694 Answers
You have to press the channel up/down (program up/down) on your remote to access different channels.
ok
Posted on May 24, 2011
Having a problem changing channels imputing into MX 3000 remote. Takes about 5 time to react to channel imput.I thought a new battery would help. It did not. Would rebooting the remote in the cabine
Presuming that the IR codes for the 0~9 numbers are captured correctly, then problems like this are usually down to either insufficient time between key presses, which can be solved by adding a small macro delay to each key; or the device being controlled is receiving multiple IR streams either directly from the hand unit and the IR emitters, or there's a blaster in the cabinet that's bouncing IR in multiple paths.
Sep 04, 2014 | Universal Remote Control MX-3000 LCD...
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
I want to program the digital channels onto numbers on the remote.
The remote will have a DASH or DOT key to let you enter the digital channel numbers directly,
as in: for digital channel 53.2, you'd enter "5" "3" DASH "2"
To program digital channels into a FAVORITEs list, you'd have to provide the Mfr/model
of the remote control itself...
Mar 28, 2011 | Samsung PS42P2S 42 in. Plasma Television
I can't move the channel selector on the remote up or down. I can depress the control but nothing happens. I can key in the channel number OK but to change channels I have to key in another number. The...
when I press any buttons on remote control cant move the channel and there is a message showing on tv screen "the operation with remote control is prohibited
Feb 23, 2011 | Sharp RRMCG1687PESA Remote Control
Hi, The number 1 button on my TV remote control takes a long time to fix on a channel like BBC 1 or channels 10 11 etc: Is this curable or do I need to buy a new one and if so from whom? many...
Hi Geoff
If it's only the number 1 button you have this problem with, then it's likely that the membrane is worn and, realistically, you'll need a new remote.
If all keys do the same, i.e 2, 20, 22 and 3 30 33 then it's probably just the response time of the TV. This is so you can enter long channel numbers like 111 without the TV changing to channel 1 or 11 before you have finished entering the channel number. Similarly, if it's on all keys, it could just be a sign that the batteries need replacing.
Anything can be fixed, but in the case of a remote control, the cost and difficulty of obtaining parts mean it's is usually easier and cheaper to buy a new remote.
You can buy replacment remotes from a variety of places, but make sure you are buying a Genuine Original OEM remote and not a third-party replacement. Beware, some shops also charge extortionate prices so make sure you shop around, but you should expect to pay £15-20 depending on which remote you have. I have used the shop below for replacement remotes and they are reliable, but not always the cheapest. Their prices do include delivery though. You will need your remote control model number when searching. On Samsungs this number is usually under the bottom row of keys:
http://www.remote-controls-shop.co.uk/
http://www.ebay.co.uk is also a good source of replacement remotes.
If you have any difficulty finding a replacement or you need any further information, please post back with your model number and I may be able to find you a good deal on a genuine unit.
Please rate this solution if you find it helpful. Thanks.
Oct 21, 2010 | Samsung TV Remote Control
Tune in channels
Switch TV on
Press “MENU” on remote until 3 blue arrows appear
Press “VOLUME” keys to tune up or down (shown on blue bar)
When required programme is tuned, input required Channel number (appears on 2 green lines at top) e.g. 02 or 14
Carry on tuning and allocating channel numbers
Select “MENU” to clear or wait until it clears by itself
Channels should now be tuned to allocated numbers
Feb 21, 2010 | Televison & Video
Can only change the channel to single numbered channels.
Three dash option does mean it will look for three numbers. You would then have to put in three digits, so for example if you want to go to channel 31 then key in the numbers 031, for channel 42 key in 042, If you want a lower such as channel 8, then key in 008. Try this.
Aug 04, 2009 | Televison & Video
My dish remote wont connect to the dish reciever
If you have a single mode receiver, you need to open the panel in front and push system info.
A channel number will appear near the bottom of the list of information... it may be between 1 and 15. Push the record button on your remote control. (the black button with the red dot). If the channel number changed, then your remote and receiver are not on the same channel. Assume your channel was #1. when you first pushed sys info. You need to program your remote to #1. On your remote, push the Sat button until all other top buttons light up. enter the digit 1 and then the # key. Press the record button 4 times. You have to make sure you have the correct color key inserted in the remote control. If you have a dual mode receiver, one remote key will be green, and the second channel remote will have a blue key. Go to the Dish network website tech portal ...Google will help you find it, for complete instructions from the horse's mouth.
May 03, 2009 | DISH Network 311 DTV Receiver
Remote control won't work with cable channels
Sounds like the TV needs to be re-set thru the menu by auto-detecting the channels and remembering them.
What kind of tv do you have?
Mar 05, 2008 | Sony RM-U185 Remote Control
Sansui D 27" TV275 TV Logo
20 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
