Question about Sony KP-53HS10 TV
It just keeps blinking in stand by and it wont stop kp53hs10 sony 53 inch tv
I have the same problem- please help- no power- just continuous blinking- tv 10 tears old
Posted on May 31, 2011
No picture
first of all sony uses blinks as a means of an error code, on older models like yours could be weak CRTs, try turning up the screen controls a little, if the picture comes on the CRts are weak and AKB is holding them dark. the controls are in the front behind the cover.
possibly you have no high voltage, D board or splitter is bad, bad convergence ICs will cause NP, check the 3.15amp fuses if any are blown replace ICs both stk392-110 and fuse to fix.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 31, 2009 | Sony KP-53HS10 TV
Tv screen will not stop blinking
It sounds definitely like a faulty power connection via the video cable from the inside. If it blinks a while then turns black then shows the picture, it would have to be that it's not screwed on properly, thus taking more time for it to get a full charge and then properly function. If you still have the warranty, any electric repair/retailer shop can fix it for you.
May 04, 2009 | Sony KP-53S65 53" Rear Projection...
Sony kp53hs10
Try (with your remote) hit Display + Channel 5 + Volume - + Power hit each key within 1 sec of each other and the tv should go into error check mode on the screen and display some data, record that and google.
Mike
Dec 22, 2008 | Sony KP-53HS10 TV
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
May 17, 2008 | Sony KV-35S45 35" TV
There is a blinking light in front of my tv blinks 8times turns off for 4seconds and starts again
Check C514 next to flyback xformer.If shorted,burnt,replace
with part # 1-161-754-00 102K / 3KV capacitor.May also have open
2 amp pico fuse in power supply......T
Oct 25, 2007 | Sony KP-53S70 53" Rear Projection...
I have sony 53 Projection TV Model No KP53HS10
First check the batteries in your remote. if that doesn't work check the setup menu. see if you have any kind of auto on\off, alarm, snooze or enabled. some of Sony's tv's had these features
Oct 08, 2007 | Sony KV-32CS70 32" TV
Sony KP-53HS10 TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
