Question about Intel D102GGC2 Motherboard
No operating system is booting
My system is not booting any operating system.even their setup is also no running and at th selection which operating is to be booted my computer gets restarted.
  • 86 Answers
Do a repair with the XP disk. boot up and choose repair then do chkdsk /p and fixmbr or fixboot
done
Posted on Aug 16, 2008
Computer showing missing boot manager
1-Insert the Windows installation disc into the disc drive, and then start the computer.
2-Press a key when the message Press any key to boot from CD or DVD appears.
a-If your PC does not detect the media automatically
b-During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
c-Look for a tab in the BIOS Setup Utility that is labeled Boot Order, Boot Options, or Boot. Following the directions on the screen, use the arrow keys to go to the Boot Order, then press Enter.
d-Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
e-Press F10 to save your changes and to exit the BIOS Setup Utility. Select Yes in the confirmation window. The PC will restart.
3-Select a language, a time and a currency, a keyboard or input method, and then select Next.
4-Select Repair your computer.
5-In the System Recovery Options dialog box, select the drive of your Windows installation, and then select Next.
6-At the System Recovery Options dialog box, select Repair your computer.
7-Select the operating system that you want to repair, and then select Next.
8-In the System Recovery Options dialog box, select Startup Repair.
http://bit.ly/2ykOBno
Oct 13, 2017 | Computers & Internet
Entering setup network selected as first boot device for current boot
That a LAN boot Rom is used does not affect the keyboard entry used to enter setup.
The BIOS controls if the onboard LAN will run on boot up.
LAN Boot ROMs are used to download operating system code from a network server. So, the BIOS has priority.
The BIOS runs first, and if you enter setup by pushing the proper key for the motherboard, you can change the boot to DVD or another device (USB Stick) to troubleshoot the PC.
Jul 02, 2015 | Computers & Internet
Hard Disk Adapter
Why would you go back to XP after having 7?
Installing any operating system:
When you first boot the computer you will see a screen that says press: F1, Delete, etc to enter setup. Once you are in setup (BOIS) navigate with keyboard arrows to find 'boot sequence'. select boot from 'cd'. Remember you have to go back and set this to boot from hard drive after you load the OS (Operating System).
Make sure you save your files, everything will be gone. Also, backup all of your drivers or download them from the internet and store them on a USB flash drive. As you may not be able to access the internet to load them.
Boot from CD>going into setup>install xp>delete partition>create>partition>setup will format drive>quick is fine>will have some prompts for selections, etc.
I hope this helps.
Oct 21, 2013 | HEWLETT-PACKARD HP Mini-Notebook...
When pc is booting , fom begining , I have 3 options. F9 =boot device menu F10 =Rom base setup or F12=NTWORK service boot! Nether 3 work. Only erreor loading operating system! Wht can i do about it.
I think you need to re-install your os for some files that the Operating System need to boot properly is missing. First, run your xp or any operating system that your using and select repair. after doing this , booting problem will no longer be a problem to you my friend. Have a nice day and i was hoping this would solve your boot problem.
Aug 17, 2011 | Computers & Internet
On the screen of my computer is sais " Boot and select proper boot device. Insert boot media in selected boot device and press a key" What do i need to insert to get my computer running?
Dear User,
Kindly enter into setup and change the first boot device to Hard Disk. Also check there should not be any pen drive connected and no disc should be in optical drive.
If still the issue persist then please boot the system with operating system disc and check if detects the hard drive and repair the operating system.
Regards,
Tech_Comp
Feb 22, 2011 | Microsoft Windows XP Media Center Edition...
I need to setup a dual boot computer. I have 2 hard drives each has an os I need the option to select at startup
Try Install KDE on your desktop, I think its much better than gnome for booting setup. There's another way which one you'd like to booth by striking the F8 key repeatedly on the restart or starting your PC and select the drive which drive you like to boot.Or you can configure it on your bios setup by hitting the del key and configure your boot priority.
Sep 11, 2009 | Microsoft Windows XP Home Edition
Reformat
step 1 - First insert the windows xp cd in your cd drive.
step 2 - Then start your computer and keep pressing F12 key on your keyboard.
step 3 - After pressing F12 key,it will show you some options to select from where you want to boot from.
step 4 - Select 'Boot from CD drive/USB cd drive'
step 5 - Now it will try to boot from your bootable windows xp cd which you have inserted in th CD drive.
step 6 - After reading the CD it will prompt you to 'Press any key to boot from CD drive'
step 7 - At this moment press any key.Remeber you will have to press any key while this prompt appears.otherwise it will boot from your Hard disk drive.
step 8 - After pressing any key it will start windows xp setup.
Thanks
Feb 12, 2009 | Dell Microsoft Windows XP Home Edition
System Restore
u can recover from the crysis by booting in safe mode after that goto control panel -Performance and Maintenance--system--in that select system restore if u hav any previous res points u r safe......otherwise a different procedure is there.............................
Nov 26, 2008 | Lenovo 3000 C200 Notebook
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
Missing Operating System error
your bought compag computer is a new one , because that error is appears only if the hard drive or the harddisk is defective or damage. Your installation of windows xp is finished totally because sometimes the error is appears because the system installation is not finished and the os system cannot read. try to re install again the windows and delete the old partitions and create again if the problem is the same even there is no error in the installation until it's finished i say that the problem is in the harddisk. Maybe the harddisk develop a bad sector in the master boot record of the hardrive
Apr 15, 2008 | Compaq Presario 700 470024-192 Notebook
Intel D102GGC2 Motherboard Logo
60 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
