Question about Dryers
PF code on Whirlpool Duet Dryer. Tech out says its the board. replaced worked a little now doesnt. doesnt quit in mid cycle. just will not start most of time. Called electrician-everything is fine he says its the dryer. checked door switch it is good. running out of options
    Sergeant:
    Novelist:
  • 185 Answers
Sounds like you have a loose connection somewhere.... I would try and check all plug connections to may sure you are getting a good connection....and that one of the pins has not come out of its holder in the plug .,.
Posted on May 24, 2011
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Whirlpool duet gas dryer PF error will not reset as per manuals
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
PF Code on Duet Electric Dryer
just press cancel ..pf means power failure ..if still not clearing probably control
Aug 15, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Sport Dryer PF code
After ranting and raving about similar issues with my own Whirlpool Sport, with no success from a ton of repairs and technicians, I decided to check the exhaust vent from dryer to outside - thinking that the dryer must be sensing an overheating problem to trigger internal shutdowns without tripping the house breaker. Sure enough the vent flap on the outside of the house had become stuck, instead of flipping open when the dryer is working. I fixed the vent flap and the problem was solved. So check all aspects of the venting - a squashed flex hose, stuck or partially closed vent flap, something covering the vent. Sometimes the simplest solutions are the correct ones.
Mar 10, 2008 | Dryers
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
53 people viewed this question
Top Dryers Experts
