Question about Dell Vostro 220 Desktop Computer
I have a dell desktop with two jacks in the front.One is marked Micophone and the other is marked headphones.I cannot get the headphones to work at all and have checked all possible volume controls.Iam not the smartest person when it comes to computers.Please help me but in easy terms.Thank You.
  • 1,179 Answers
Some-times those connectors are not connected to the respective plug in points on the mainboard. That is a possible reason for them not working.
A solution to this problem would be to open up the chassis and ensure that the ports are indeed plugged into the mainboard.
Intel based computer systems use AC'97 and AMD based computers use HD Audio.
You may need to consult the mainboard manual to correctly plug the ports in.
The other way is to use the ports located at the rear of your computer chassis, however as you may have experienced it may mean that the cables on your mic/earphones are not long enough. In which case you will have to check that the front headers are plugged in.
Remember that when using a microphone you need to specify which port/audio in port you are using rear or front.
Take care!
damnor01
Posted on May 25, 2011
Headphone jack is broken INSIDE the port and is overriding the speakers. Can I override this override?
Or instead of having to open up your computer and messing with the mobo. Just use the control panel in to disable the headphone jack.
May 09, 2014 | Dell OPTIPLEX 745 PC Desktop
Dell laptop headphone sound on out headphone no sound
Sound Loss in Dell Computer Headphones b> Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Dec 29, 2012 | Hitachi VisionDesk 1330 (1330-001) PC...
Dell inspiron 1525 not getting any sound out of headphone jack...I have 2 headphone jacks on the front of my computer. The right one has always worked when I plug headphones or sound cord in. Today, I...
The jack might need replacement since it may be broken on the inside. Also check with your headphones on anther known working device to make sure that the issue is not with the headset.
Sep 03, 2017 | Dell Inspiron 1525 Laptop Computer PC...
How do i use earphones to listen to music and video on my computer
The lighter gray, curved front panel of the computer can be flipped up to expose two usb ports and a headphone jack. Plug your headphones into the round hole.
Diagram halfway through this article:
http://support.dell.com/support/edocs/SYSTEMS/dim4300/tour.htm#1101572
Mar 05, 2011 | Dell Dimension 4300 PC Desktop
Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | E-Machines T2898 (764296109563) PC Desktop
Can't get headphone jack on front of computer to work
The headphone jack up front may not be connected to the PC's integrated audio on the motherboard (or to the PC's sound card if you purchased one with the system instead. There'll be an audio cable running from the front of the computer to a port on the motherboard. If you look at this motherboard diagram for the Vostro 220 (not the 420 or 220s), it'll be the port numbered "15" that's the opne for the audio for the front panel. You don't need the speakers plugged on the back to have the headphones work, but having them plugged in will at least tell you if the sound is working or not.
Mar 27, 2009 | Dell Vostro 220 Desktop Computer
Dell Inspiron 1525 : headphone and mic problem
That front panel jack option is probably a feature included in some Dell software that you installed on the computer. Go to dell.com and find the audio drivers and install all of the drivers that look like they would apply to your system.
Feb 25, 2009 | Dell Inspiron 1501 Notebook
Microphone and audio jack not working on dimension e510
look in the sound settings you may find the front panel audio and headphone have been deactivated, or try to re-install the sound drivers again, if there is any on-board audio, go into the bios settings and dissable it
good luck
Nov 17, 2008 | Dell Dimension E510 PC Desktop
Dell Vostro 220 Desktop Computer   Logo
81 people viewed this question
Alun Cox
