Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
My Whirlpool gas dryer is not turning on. I press and hold the control on button. Some of the panel lights, light slightly but the dryer will not come on.
    Scholar:
  • 142 Answers
Do you hear a loud buzzing? That would indicate a stuck motor. If you hear nothing, you could have a burnt temp fuse, which is in the motor circuit. Of course, there could be a loose connection anywhere in the circuit which would take time to find.
Posted on May 24, 2011
Whirlpool cabrio gas dryer model WGD6200SW1,
I would hold door button in with door open does it heat if so I would look at belt that turns drum if broke or just came off lower drive pully.hope this helps
Feb 12, 2015 | Whirlpool Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The control lock button is light up and the washer won't work.
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 23, 2010 | Whirlpool Washing Machines
Dryer GEW9250PWO control panel will not work or light up. Lamp inside dryer works. Also hold End Of Cycle button down and does lock panel...but still nothing other than that lights up. Any ideas?
Take a close look at the front LED panels, are some of the LED's lit up ever so slightly when this occurs? If so, it seems to be a very common problem with Whirlpool.
Nov 28, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
"CONTROL LOCK " light is on. How do I get appliance to work?
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
Mar 15, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool dryer just beeps when you try to start it. The panel is lit up the door is shut, push start and it just beeps...any idea what the problem is
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
http://www.searspartsdirec t.com/partsdirect/getSubComp.pd?modelNumber=GGW9250PW1&productCategoryId=0151200&brandId=1198&modelName=RESIDENTIAL-DRYER&diagramPageId=00001&componentDescription=TOP%20AND%20CONSOLE%20PARTS&documentId=W0508037&blt=06
Jan 09, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet gas dryer has CONTROL light lit with malfunction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$#$#$
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer will not start. Panel lights come on as usual and when press start machine clicks and will not start. Light on wet sensor lights and no drying action begins.
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Dec 01, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet ggw9250pl1
On Duet models, Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Jan 02, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
