Question about HP Desktop Computers - Hewlett-Packard 2.93GHz Intel Celeron D 100GB Desktop Computer with DVD-ROM/CD-R... (A1100NPX739AA)
I have an 8 year old TV with no VGA input, just an S-Video input. My computer does not have a S-Video output. In order to use my TV as a monitor, is there an adaptor of some kind that would allow me to connect my computer to the S-Video input of my TV? Thanks.
    Problem Solver:
  • 12 Answers
You can do this with a VGA to TV convertor. This is a device that converts the VGA signal from your laptop to a signal that your TV displays. It simply plugs into the VGA port on your laptop, as you would a monitor or projector, and into your TV.
I frequently use these devices, and they are very simple to use, with good results. You can find an excellent model at http://sewelldirect.com/pc-to-tv.asp. Or by searching for a PC to TV Converter.
Hope that this helps you!
HelpDeskMan
Please rate this post and/or leave comments. Thank you.
Posted on May 24, 2011
How do i get my westinghouse sk 26h730s monitor to work with my HP desktop computer with windows XP?
There should not be a driver required for this. As long as your HP desktop has a VGA video or HDMI video output, you can connect to the back panel of the TV from the video port of the PC. Then, on the remote, select the "PC" option for VGA input, or HDMI for the HDMI 1 or 2 input(s). If the PC only has DVI output, then it is important to know if the output is analog or digital. If it is digital (DVI-D or DVI-DD] then there is no available port on the TV to support it. Using a DVI-VGA adapter on a DVI digital output will not work as there must be a digital-to-analog conversion in order to work.
Sep 01, 2014 | Westinghouse Electric SK-26H730S 26 in....
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
Dec 13, 2012 | Computers & Internet
How i use my samsung CRT TV as a computer monitor? my TV has A/V and RGB input connectors. and My PC has only VGA out put.
You'll need a VGA to Video composite / S-Video converter (commonly called PC to TV converter), this device will allow you to connect the VGA output to composite video input of your TV.
Feb 24, 2011 | Computers & Internet
Emerson 42 inch television flat screen HDTV: i connected a DVI to HDMI cable to dell computer screen to television in order to display computer screen to it but the signal isn't working, how do i...
Your Dell Monitor does not have a video output. The DVI/HDMI cable needs to run from the DVI-Out of you computer tower directly to the TVs HDMI input, ideally one with a red/white analog audio input next to it, because that cable only provides a video signal. If you don't have a DVI out on your computer, perhaps your TV has a VGA input. If your computer/video card only has one monitor connector, then you can only connect the Monitor OR the TV.
Dec 27, 2010 | Emerson Televison & Video
How i can connect the tv as my computer moniter
Does your TV have a "VGA" input? If so, then connect the VGA-output from your computer's video-card to that VGA-input.
Does your TV have a "DVI" input? If so, then connect the DVI-output from your computer's video-card to that DVI-input.
Does your TV have a "S-Video" input? If so, then connect the S-VIdeo-output from your computer's video-card to that S-Video-input.
Note that only _SOME_ video-cards have DVI output or S-Video output. Check your video-card.
Dec 01, 2010 | Computers & Internet
Can this be used as a monitor for a computer?
Hello
Sorry. The answer is you can't. Computers output comes as VGA [Video Graphic Arrey],or AGP [Advanced Graphic Protocol]; and it is not directly compactable with TV inputs. The computer outputs, Red_Green_blue and Horizontal and Vertical synchronisation signals seperatly through one VGA cable which goes into the monitor and there they gets processed and you see the image on computer monitor. Monitors are equipped with such circuits to process the same, whereas in the TVs there are not. Your TV is equiped with S-video connection and not have a VGA input connection.
You must buy a VGA to RGB converter for this purpose. It can be bought from the electronic market, and will have instructions and remote control of its own to control it. You must give the computers signal [VGA], to the input of that converter,with a [VGA to VGA] cable and from which the converter outputs R_G_B [Red_Green_Blue] along with an other output contains synchronisation signal, as described earlier, and will have directions in its manual where should it to be connected. Different converters have different confugurations for this connection, and it will be described in its manual. Ok.
Oct 29, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
How to connect my pc to my tv & use it as a monitorbaxterstead000@hotmail.com
-get a vga cable(usually both ends are male) - connect it to the vga port on the laptop then the other end to your tv -press fn+f2 to switch the display to your tv( this is model/brand dependent, check your user's manual for more info)
Oct 23, 2010 | Computers & Internet
Want to use my tv as a monitor, how do I activate the vga output?
Hi adiazjr.On the Asus 1000he, in order to switch to an external monitor you need to press the function key (Fn) at the bottom left of the keyboard and the F8 key at the top. When you press both of these keys at the same time it will send the video signal to whatever external monitor or TV you have connected. Hope this helps!
Aug 28, 2009 | ASUS Eee PC 1000HE Netbook
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Computers & Internet Logo
49 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
