Question about Canon PIXMA iP90v Printer
Canon Pixma ip90 printer
Am getting a error 5100 and 5600. Got fixes?
Service error 5100
Posted on Jan 04, 2009
How to work a Canon PIXMA iP90 printer in win 7
Hi miggoservo,
If you cant use your printer, you need the driver. Try to click the link: http://drivers.softpedia.com/get/PRINTER/CANON/Canon-PIXMA-iP90-Printer-Driver-Vista32-200.shtml
Hope this helps.
Thank you for using Fixya!
Sep 24, 2011 | Canon PIXMA iP90 InkJet Printer
I have one printer canon Pixma IP90. Please advise me to solved : "Canon PIXMA iP90 Service error 5100". Thanks so much !
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 29, 2011 | Canon PIXMA iP90 Mobile Printer
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 Canon Printer shows error code 5100: How do I fix it?
This means there is something jamming the mechanism. You should take it to a repair specialist or do your best to check for blockages yourself. It can be the tinest little thing. Check everywhere!
Sep 01, 2009 | Canon PIXMA iP90 Mobile Printer
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Jul 21, 2009 | Canon PIXMA iP90 InkJet Printer
Canon IP90 Service error 5C00
BCI - 15 is not the same as the BCI -16. The look and feel the same, but the ink is handled differently by the printer - so while, in theory you could use them interchangable, the output would be terrible... Canon set it so that you can only use a BCI 16 in an IP90.
Buy a BCI - 16 cart and try that.
Mar 22, 2009 | Canon PIXMA iP90 InkJet Printer
Cananon iP90 error 5100
have the same message posted need to know ASAP!
Jul 31, 2008 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA  iP90v Printer Logo
628 people viewed this question
old marine
old marine
