Question about KitchenAid Microwave Ovens
Kitchenaid trash compactor bought in 2000; no model/serial number found. Compactor was stuck in partial down position; worked the drawer out and found cotton fibers wadded/stuck at top of the up/down screw mechanism; got most of the fibers out; worked the mechanism loose, but now it keeps trying to go up, makes loud/bang noise and won't stop doing this. How to fix it if I do it myself? Is it worth having it professionally repaired/cost wise vs. buying new unit?
    Scholar:
  • 142 Answers
At the top, above the ram, there are two switches. One is the reversing switch (should have 4 wires), the other is the stop switch (2 wires). I suspect that the switch arm is bent, due to what you just described, and fails to activate the switch to stop the motor when the ram is at the top position.
Posted on May 24, 2011
I have a GE Spacemaker microvave oven that was working perfectly for the past 4 years. When installed, we were told that the outlet did not work, so to get the microwave working, the cord was pulled out...
Perhaps the microwave's main supply fuse has blown.Open the cover & check it in the power supply section.Be careful & discharge the big capacitor first as there is very very high voltage present inside even after switching off.
Mar 07, 2012 | GE Spacemaker Over-the-Range Microwave
Where do i find model of hotpoint range
generally it will be behind the bottom drawer on the right hand side (unlike most other models which are on the left hand side)
there will be an aluminum plate with the model and serial number. Hope this helps
Jun 10, 2011 | Microwave Ovens
Ignitors continue to pop altho all four knobs are in off position Kitchenaid gas stove top Model #KGCT305X Serial #XB2806974 ir X52606974
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 21, 2011 | Microwave Ovens
It's a GE microwave..model PVM1870SM1SS...mfg. 10/07..panel light is VERY dim...cannot read unless you shade all light with hand otherwise works fine...tried re-boot twice no affect.All other GE...
It sounds like you need a new display, if it is neon or a new back light if it is an LCD.
Contact the manufactureres web site for details of a dealer in your area for spare parts.
Hope this helps.
Nov 16, 2010 | GE Advantium 120 Convection/Microwave Oven
The trash compactor won't open and it locked shut. When the dial is on the "ON" position, the unit just hums.
Check the mechanism for the door failure as the link could be caught up . open the top cover and find this out.
The hum could be the failure of the capacitor which could be short.
The microwave will not work then, so replace and check this out.
Aug 21, 2010 | Microwave Ovens
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. I have checked the...
Sounds like the motor that turns the reduction gears which ultimately pushes the ram could be seized up. If an object was jammed inside which was to much for the motor to handle it could cause it to draw too much current seize up the motor.
Jan 24, 2010 | Microwave Ovens
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. Now, I can't even open...
We had the very same problem. Pull the compactor out and unplug the unit. Lay it on its side and remove the bottom. This will expose the chain and gears. On our unit, the plastic sprocket was broken. This part turns the chain to make the ram go up and down. When I called about a local location to buy a new part, I was given 1-800-688-9900 to phone for help. Tell the automated service you want "parts" and you will get an operator. I described the part and she said that is was no longer made in plastic -- it's now metal. The part number she gave me was #675370. I could've ordered the part through them and would receive it in 3 business days. With our zip code, she was able to give me two locations in our area to get the part. One place had the plastic part -- no thanks. The other place was able to get the part in the next day. Hope this helps more than solutions 1-3.
Jan 23, 2010 | Microwave Ovens
Turntable not working
Go to the web and type www.partselect.com or www.applianceaid.com enter your model number then scroll down to your part. Click to enlarge exploded diagram and veiw the entire diagram for exact assembly. Now you have information you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
109 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
