Question about Carrier 38CKC036 Air Conditioner
8 year old Air conditioner only used in the last 3 years more than a week or two a year. capacitor changed last year Unit was working a week ago now fan is not turning, Connector clicks when turn on and off. when on I turn fan manually to see if motor might kick in and it does not. No lose wires. Quiet when turned on.
    Scholar:
  • 127 Answers
Outdoor units require there own power supply, check the breaker panel and the fuses in the disconnect switch box next to the unit if there are fused, If the capacitor that was changed last year was not the right rating or configuration it may need to be corrected. One of the most common mistakes is to find a dual run capacitor with on side not functioning and jump in a capacitor for the non functioning side, if this was done it needs to be corrected with the proper capacitor or capacitors.
Posted on Oct 21, 2011
Compressor quit working. 3 year old unit.
All parts on Goodman equipment have a five warranty from the factory. Capacitor may have gone bad, check electrical compartment for swollen,bulged capacitor inside, should be flat on top where the electrical wiring connects, if a uf testing meter available it will verify capacitor, remember to shut off power first.
Aug 23, 2011 | Goodman CLJ60AR61 Air Conditioner
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
Keeps flashing ES, not cooling. Not even one year old.
The 2 most common issues are a freon leak or the outside unit fan start capacitor goes out. It's more likely a capacitor issue. They fail regularly, especially when it's as hot as it's been this year. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Aug 14, 2011 | Frigidaire FAC106P1 Thru-Wall/Window Air...
Frigidaire Air conditioner: fas296n2a2 Compressor
Do you have an amp meter? and volt meter. Are you sure that the compressor is getting power? The click may simply be a relay closing but no power. Check both sided of the relay. You will need to trace the power and make sure that the compressor is getting power. Then check the amps to see how much power it's pulling.
Jun 15, 2010 | Heating & Cooling
Compressor wont come on
Check thermostat. Compressor relay. Compressor capacitor.
May 27, 2010 | Frigidaire FAA068P7A Air Conditioner
How to tell how old my admiral air conditioner is?
usually the serial number of the unit will indicate when it was manufactured. It is generally the first 4 numbers indicating the week number and the last 2 digits of the year but the formats do change over time
Jul 31, 2009 | Heating & Cooling
Our air conditioner unit turns on but just blows hot air
our unit is realy a coleman unit but You did not have that listed.
In any case it started back up again and I was so releaved as it was at least 103 degrees yeasterday. But i haove a feeling this may not be the end of it .
I may need your service at a later date.
Thank you for your quick response.
Jul 29, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Jun 28, 2009 | LG Heat cool Window Air Conditioner
I have a Jantrol heat pump & A/C. It is approximately 10 years old. For the last 3 summers the compressor unit will freeze when the air handler fans fails to come on. It worked fine for 2 weeks this...
If you can safely check the supply to the motor when it should be on, then this is the best method to check it.
Check the fan turns very freely - oil the bearings if it doesn't.
If there is power there, but it does not turn, replace the run capacitor.
If this get's you going - Please rate as Fixya so others may benefit. Thanks!
Jun 26, 2008 | Goodman Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
61 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
