Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
MY refrigerator is making a grinding sound that goes away when I open it, but returns when I close it. I also keep finding water in the produce drawer.
    Scholar:
  • 142 Answers
That sounds tike the inside fan needs to be replaced.
Posted on May 24, 2011
2006 BMW R1200GS - whilst riding no noise but when I close the throttle it makes a grinding sound. It goes away when I pull in the clutch. It is a tyoe of revolving grinding noise.
May be broken snap ring which keeps gears in proper position, but since you posted this in the wrong category, don't expect many answers.
Dec 28, 2014 | BMW Cars & Trucks
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
My HP950 keeps giving me the message that I have the wrong size color cartridge. Why?
Turn off your printer
Open the cover
1Open the cartridge carrier Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean specially the gold plate.CLean also the area where you return your cartridges also the gold plate make sure its clean OK .
2.return it properly close the carrier properly make sure there's a snap sound produced .Move again the cartridge carrier manually from left to right 5x
close thecover
try to turn it back on
May 28, 2011 | Office Equipment & Supplies
The Whirlpool side-by-side refrigerator, model ED2KVEXVQ01 occassionally leaks water onto the floor. There could be a cup or more of water, but the problem has occurred a few times, but may go weeks or...
sometimes we overload our refrigerators and the doors will not close properly, next time you notice the water see if your doors are closed tightly and the seals engaged tightly. My wife has this habit of not checking after she has put away the remains of a big dinner or BBQ and I find drips of condensate water all over the floor as a result. The defrost collection pan overfills and the excess water goes on the floor. once the doors are closed properly the problem goes away.
Aug 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
Our refrigerator just suddenly started to make this loud grinding sound..it appears to be coming from the freezer side. I turned off the ice make and reduced the freezer temperature but it still keeps...
This could be a failure of the evaporator fan. Also maybe some ice has formed from water dripping from the ice maker and had now produced an icicle which could be hitting the fan blade of the evaporator motor. Remove back cover to the freezer/fan and check the fan operation while it is running.
Mar 29, 2010 | KitchenAid Refrigerators
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Loud grinding noise
the gear may be wearing out.
Jul 31, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Maker Making Noise
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
245 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
