I have an HP DV6000 and I can not get the keypad or the buttons to work. I have checked all the cables and they seem to be tightly connected. I loaded the software and drivers, but nothing.
  • George Maeweather May 24, 2011
    Thank you, I agree with your solution.
  • George Maeweather Jul 13, 2011
    Thanks very much. I tried that already and it did not work. The laptop just happens to be out of warranty.
  • 2,632 Answers
Welcome to Fixya. Would like to verify when you mean you check all the cables, Did you open the case of the laptop? Loading drivers and software will not fix the issue because the keyboard will works even if there is no Operating System installed on it. You can try to do a power drain by removing the battery for 3-5 minutes and after that put it back on. The process will drain all the power in the motherboard. If this won't fix the issue it only means that this is a hardware failure. You need to replace it or if the laptop still have a warranty with HP then you can ask them to replace it for you free of charge.
Thanks for using Fixya.
Posted on May 24, 2011
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
My CD/DVD ROM IS NOT WORKING WHAT COULD
Does it seem to be missing altogether? There is a Microsoft Fix It page here: http://support.microsoft.com/gp/cd_dvd_drive_problems
Click on the "Run Now" button.
Apr 22, 2010 | HP Pavilion dv6000z Notebook
The monitor on my laptop does not work. The laptop starts up by pushing the power button but the monitor does not come on. Its a HP Pavilion dv6000.
now u put the monitor to ur laptop by cable vga and u use fn+f4 to wiew in external monitor if u can see ur lcd laptop are problem, if not see anything u much check before ur memory try with another memory. good luck 4 u
Jan 14, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
2006 saturn ion door locks and trunk pop wont work....
The remote won't ework because the problem is in the vehicle. Just for test purposes and possible remedy. Remove and clean the negative battery cable. Ensure a clean , tight connection. Then find the body ground. Yhis ground is locted usually at the top rear of the engine. .I's a snall stainless steel strap bolted to the engine and fire wall, This must olsobe clean with a good contack. Might as well clean the + cable and connection on the battery while you are there. Good luck and keep me posted olease. Good Luck, Ned_
Oct 03, 2009 | 2006 Saturn ION
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
Pavilion dv6000 when power button is pressed,
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
Jun 19, 2009 | HP Pavilion dv6000t Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
