Question about Cameras
Hi i want to install 2GB memory card , previously i use 16MB memory card, by the way when i want to install then show format when i click that button then show error what can i do please suggest
    Sergeant:
    Champion:
  • 214 Answers
Hi would you tell me name of your camera model first. Thanks and best regard!
Posted on May 24, 2011
Ma memory card memory 2gb has convert to 0 bytes ,plz help me my email; sana_ullah87@yahoo.com
Put the memory card back into your computer or card reader and open My Computer. Right click on the card once it is recognized and choose format. When the format box comes up, look at the capacity. It should show around 1.89GB on a 2GB card. If it shows zero, your card could be bad.
Jan 28, 2011 | SanDisk 2GB microSD Memory Card
My microSD card memory is a not formating accept and not deleting old files.
HI there,
It seems that your memory card is infected with the virus which restricts you from formatting,
To Format the memory card:
Take out the card from the cellphone, Insert your memory card in the card Reader, (External more preferably or internal memory card if you are using laptop),
When window recognize that memory card is inserted , Just hit cancel and do not open your Memory card.
Right click on my computer and select Manage Then Select Disk Management it will show you the list of installed Hard Drive, DVD , and memory cards, right click and select your memory card (On the left size you can see the size of the memory card) and select Format, a pop up screen will come and you can select format options. Select Perform a Quick Format. and then click OK, it will format your memory card, and all the data will be erased from the memory card,
Caution: Always select the right partition in Disk Management for formatting to avoid any possible data loss,
If you require more assistance, feel free to reply to this post
Regards-BA
Jan 16, 2011 | SanDisk 2GB microSD Memory Card
I am unable to format my memory card? i have purchased new sandisk 2GB micro sd memory card,but in few days this problem will occur
We Wish You a Happy New year.
Right Click on the Memory card and check for properties and see, if it is showing 1.85 gb then you need not format or try to format in FAT32 if you are using NTFS.
Hope this helps you. Cheers!!!
Jan 03, 2011 | SanDisk 2GB microSD Memory Card
Hi, I have got an Olympus mju 300 Digital camera, and I have bought a 2GB XD Type M+ memory card, however when I put the 2GB memory card in, it takes the camera a good 15 seconds to start up, whereas with...
There are several reasons why could happen:
1. 2GB is a lot of space compared to 16MB. The camera checks the card each time you switch it on.
2. Card is corrupt & should be reformatted.
3. Card is defective & should be replaced.
Oct 05, 2017 | Olympus MJU 300 Digital Camera
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Sandisk 2gb sd card unable to to format and shows 30.6mb.how to recover the data
Hi
Please follow these steps to recover the data from your memory card.
1. Go to http://www.recovermemorycards.com/
2. Download the software from the website.
3. Install it on your computer and recover the data from memory card
Jul 30, 2010 | SanDisk 2GB microSD Memory Card
2GB microSD card "disappeared"
please try it. friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
Jul 20, 2010 | SanDisk 2GB microSD Memory Card
Can my finepix a900 take a 4mb memory card
hi
the camera supports the following
Internal memory (approx. 10MB)
xD-Picture Card™ (16MB - 2GB)
SD memory card - 2GB
happy clicking
pls rate if this was any help
Jul 13, 2009 | Fuji FinePix Z1 Digital Camera
I have a Kodak LS743 and am trying to put a new SD 4GB into it and it won't let me format it. WHY???
Your Kodak LS743 camera is built to use the SD memory card standard - which only goes up to 2GB. Any SD card over 2GB is a new format called SDHC (high capapcity) and isn't compatible with the previous format. This is why you can't use your 4GB card - you have to use a 2GB card.
Jun 28, 2009 | SanDisk 4GB microSD High Capacity Memory...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
