Question about Skull Candy HESH Consumer Headphones
The chords to my headphones got yanked really hard and now I dont get any sound out of them. There is probably a short in the chord now or something maybe got disconnected on the inside. Any suggestions?
  • Skull Candy Master
  • 5,487 Answers
Have a look at my tip on headphone problems just click my user name to find it.
Posted on May 26, 2011
Kenwood how to connect
You need a stereo mini to RCA cable to connect the laptop's headphone audio jack to the Kenwood. Here is an example of one below. They are very common and available at just about any electronics store for a few bucks.
http://www.amazon.com/Gemini-PH62089-Stereo-Mini-Male-RCA-Male/dp/B0001GAOE0
The Kenwood receiver should have a number of red and white "RCA" audio connectors on the back.
Just connect the RCA portion of the cable to a spare input. They should be clearly marked on the back of the unit and color coded (red for right channel and white for left channel). But it really doesn't matter if you mix the right and left up, it will still make sound.
EX:
Most receivers will have inputs that are labeled "CD" or "Aux" that you can connect any audio source to.
If you connect your laptop or an MP3 player to the audio input connections labeled "CD" behind the Kenwood receiver, you can listen to the device by selecting the CD as the source.
It is really easy!
May 04, 2014 | Kenwood VR-305
Headphones' doesn't work unless i pull the chord
the cable needs remaking as it brakes after excessive movement at the very end, good look
Apr 11, 2012 | Audio Players & Recorders
How to repair a ps2 that is not showing on tv set
check to be shure that the tv is on imput.
the cord could have a short sou u might could find the short somehow and rewire that part or check inside the ps2 for unhooked or broken chords around the spot that the chord hooks up.
if those dont work u might try to buy a new chord.
Mar 15, 2010 | Sony Video Game Consoles & Games
Hi my Marshal G15 is making an echoy twang when played loud (& open E chords). does this mean the reverb is broken?
I suspect the vibration when it is loud is vibrating a reverb tank within the unit.
Test this bylistening with headphones and see if you get same sound.
It may be the reverb has a resonance or the cabinet does that is sensitive to your E chords.
The shock mounting of the reverb may have failed to isolate the reverb tank from speaker vibrations... hence the headphone test.
Jan 27, 2010 | Marshall 15 Watt Guitar Amp
No sound
check if the A/V chords are firmly in place. (The yellow, white and red plugs). If it is firmly in place, and the sound still does not come out, the problem is that there is a loose chord. Try slightly bending the chord while testing if there's sound. This way, you'll know if it really is the chords that have a problem... hope this helps!
Jun 22, 2009 | Sony PlayStation 2 (PS2) Console
Xbox 360 wired controller
no shorts??? hmm well just to be sure take both hands and start mangling with the cord work your way up and if your controller reconnects when your doing this you will need to replace the chord. unplug your chord from your console blow in the USB circut where your controller plugs in there might be dust in the plug in blow in it really hard and pliug it back in if that doesent work plug it back in go to your controller USB settings and see if it has a signal from the chord Hope that helps:)
Feb 19, 2009 | Microsoft Xbox 360 Controller
Still won't work
Have you tried using someone else's recharge chord? I'm thinking that your chord may be broken which is why it won't charge or turn on. If you are using someone else's chord and you know that it works but your DS still won't turn on, there is something wrong with the port which you can't really fix. If you still have your warrenty I would send it back.
Nov 09, 2008 | Nintendo DS Console
Replacement Chord
try radio shack.
you could also take an 1/8 to 1/8 4' cable which will run about 10 dollars or close to it and cut one end off then splice it back in to your headphones.
Jan 21, 2008 | AKG K 240 Studio Professional Headphones
Skull Candy HESH Consumer Headphones Logo
116 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Joe Lamb
Joe Lamb
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
