Question about Hunter Ceiling Fan Control Switch
The pull switch (that controls the fans speeds) broke and while replacing the switch, it fell off and now I don't know which color wire goes in L,1,2,3.
  • 1 more comment
  • linnybeebs May 24, 2011
    Thanks! Combo 1 are the colors I have but I tried that combo and it had 2 settings on high and 2 off
  • linnybeebs May 25, 2011
    Thanks! I was able to get the speeds working! But now the light won't work...I didn't touch any of those wires....now what?
    Thanks again!
    all the wiring seems fine/connected properly...the only thing that seems off is what looks like the ground wire...(black wire coming from the light with metal piece on the end of it)....is that supposed to be positioned between the bulbs inside the black encasing?
  • 5,370 Answers
First combination:----
colors: L=black; 1=grey; 2=brown; 3=green.
second combination:--
L=black, 1=grey, 2=brown, 3=purple wires.
Third combination:---
Orange - 1, purple - 2, white - 3 and black - L.
The procedure is as follows:-- Black wire always connects to L.That is hot wire( 120 volts).The high speed wire connects to 1 the low speed wire connects to 2 and medium speed connects to 2.
All the 3 possible wire combinations are given.check what color wire you have and connect as per that.connect wire tight and intact.And this should help.thanks.Helpmech.
Posted on May 24, 2011
  • 1 more comment
  • raj somaiya May 24, 2011
    Check the opposite side wires too.Is it got loose from its soldering or connections.---------Also if you try connecting your fan as per combo 1, does the fan starts running.------
    As per combo 1 setting the grey is high and brown is medium and green is low.-------
    Thanks.Helpmech.
  • raj somaiya May 25, 2011
    without any mistake, just remove and reconnect every wire properly.The light wire is mostly blue wire.So re check and reconnect blue wire.Connect red wire the light hot wire (often blue, sometimes black with white stripe) .the red wire connects to light wire.so check the connection between red wire and blue wire.You can just check the wire coming out of light fixture.that wire should go to red wire.--------------
    This should help.thanks.Helpmech.
    Yes try doing that and see, if that makes a difference.Keep updated.Thanks.Helpmech.
How to install new ceiling fan 3 speed switch with the 5 wires on the condenser?
Sales person should have written down what color wire goes into which slot on the switch. If you have two wires on the same end, and the same color, one of these goes into the #1. Black usually goes into the L slot. But, none of this matters if you don't have the correct switch. Just because it looks the same on the outside doesn't mean it's the same on the inside.
Oct 05, 2015 | Dryers
How do I replace pull chain on old hunter fan. No replacement available Home Depot gave generic switch. I don't know what wire color goes in switch L 1 2 3 Wire colors are red black blue
If that's a two speed hunter, you have the wrong switch. You need to get a two-speed switch. This switch comes with the wires attached. Do you have the fan model?
Mar 15, 2015 | Hunter Dryers
How do I replace the 4-wire fans speed control in the Heritage 5ALW52PB3P with a 3-wire speed control?
You have to replace the switch. You cannot open & fix. First, write down which color wire goes into which slot on the switch. Each slot should be marked, usually L,1,2 & 3. DO NOT CUT WIRES. I don't know this fan so you'll have to get a switch where you bought the fan. Otherwise, I need to know how many wires on your capacitor & which slot on the switch they go into. Remember, just because a switch looks the same on the outside doesn't mean it's the same on the inside. fanman9952@aol.com
Sep 15, 2014 | Dryers
What current Zinger switch would be used to replace a Zinger ZE 208S?
How many wires on the capacitor & which color wire goes into which slot of the pull chain switch?
Aug 12, 2014 | Hunter Dryers
Fan switch for fan light combo
Unfortunately, there is no standard color coding for ceiling fan wiring. You note in your video that the replacement switch has an L(ine) terminal and there should be 1, 2, and 3 terminals as well for controlling fan speed. Check the switch you are replacing for similar marking. If you are in luck, you can replace by L and numbers rather than colors. I checked my entire file of fan installation information and nothing more explicit is provided
May 24, 2013 | Photography
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
http://www.kenselectronics.com/lists/switches.htm#Pull%20chain
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
Nov 30, 2010 | Hunter Ceiling Fan Control Switch
Speed control switch
I saved this text I found when I was researching this a while ago.
Let us know how you do.
Wiring a three speed fan switch
My daughter called me the other day and said Dad the ceiling fan in the kitchen is not working only the light works. I went over and removed the three screws that hold the light and pull chain for the fan down and found that the fan control switch had snapped open and all 4 wires had popped out. The snap clips on each side of the switch had broken off. I went down to Home Depot in the ceiling department and found the switch I was looking for. It said for a four wire ceiling fan. OK, know lets put it back together. First of all if you look at the new switch you should see four holds were the wires will be pushed into. The black wire in the fan is the hot or load wire, this wire is hot whenever the wall switch to the fan is turned on. Put this wire in the hole that is marked “L” this stands for load. Now with this switch in the off position the fan will not work until you pull the chain. The other three holes are marked #1, #2 and #3. On most fans #1 is usually high speed. # 2 medium and #3 low speed. What you now have to determine is what wires are high medium and low. The easiest way to do this is before you put any of the wires back into the new switch is to FIRST MAKE SURE NO POWER IS GOING TO THE FAN. Then simply take one of the colored wires at a time and twist it together with the black hot wire.
Turn the power back on to the fan and knot the fans speed. Do this with all three wires one at a time until you can determine which wire is high speed. Note the color of the wire and mark it down on paper.(Example; blue wire high speed.) Do this with the other two wires to determine there speed. Once you have the speed of each wire you can reassemble the new switch.
Black wire (Load) goes in hole marked L. High speed wire goes in hole marked # 1. Medium speed goes in hole marked #2 and low speed goes in hole # 3. MAKE SURE THE POWER TO THE FAN IS TURNED OFF WHILE YOU ASSEMBLE THE NEW SWITCH.
For those of you that have all these wired hooked up right and still the fan won't work I would then look for an open neutral wire. It should be a white wire. Check to see if all the wires are securly attached.
Good luck. One more word of advice. If you're not sure on what you are doing when it comes to electrical wiring then please do not attempt to do this or any other electrial work yourself. Call a licensed electrian. Any mistakes on your part could void your home owners insurance in case of a fire.
Aug 06, 2008 | Hampton Bay 24002 Ceiling Fan
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
411 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
