Question about Sanyo Xacti VPC-T700 Digital Camera
Viewer screen is white, i can record and playback but the screen is white, its an xacti waterproof 6mg model
    Sergeant:
    Champion:
  • 214 Answers
Hi Usually white screen problem is defective lcd unit. your local repair shop would charge $45 to 75 depend on what they want to charge. Thanks and best regard!
Posted on May 24, 2011
Hi i have a sanyo xacti vpc-ca100...there is no picture on screen when i want take a picture or record ...but everything else works fine menu setting playback of stored picture etc...
Are you sure the lens is actually opening ? Next time you use it, examine the front of the lens to see if the lens cover has opened. If it has not, that is the reason. You may be able to get it repaired, but at a cost.
Aug 08, 2016 | Sanyo Cameras
I have a Sanyo Xacti FPC-FH1 with a 32g SDHC card. I can only get 4g of recording time. The recordings after 4g have a big" ? " in the display when I list the recordings in playback mode, and while...
You could plug the card into your computer using a card reader and then right-click on it. Click on properties and it will give you the used and unused space.
Jun 27, 2010 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo xacti digital camcorder screen not working when opened out
Hi!
It's most likely a damaged LCD cable which goes through the hinge - happens to many camcorders. You will have to contact your local Sanyo service center. I replace these cables for Sony camcorders every day.
Sorry for the bad news, but hope this helps.
Tom
Sep 27, 2009 | Sanyo Xacti E1 Waterproof Camcorder
Video stopy recording
I guess there's only so much room for videos on the internal memory... I did a full format, problem solved!
Sep 15, 2009 | Sanyo Xacti E1 Waterproof Camcorder
LCD Screen Stays Black
Had the same problem. It nearly drove me mad, however, the fix seems quite simple. The screen in playback mode seemed to be fine but if I swithed to record or photo mode I just got a black screen. I could see some pixel movement so I figured the screen was okay and that the iris was the problem.
Anyway, to fix it I simply gave a few sharp taps on the camera body near the lens. This unstuck the iris and I was greeted with a clear image in the LCD viewfinder. The camera now works fine.
By the way, this seems to be a fairly common problem with a lot of the different models and not just limited to this one.
Hope this helps.
Nov 25, 2008 | Sanyo Xacti C6 Camcorder
Black screen
Try removing the battery and putting it back in again. This happens to mine. Also make sure that the SD card is fast enough. I.e. a 40x SD or more card or a class 6 SDHC card.
Jul 23, 2008 | Sanyo Xacti VCP-HD2 Camcorder
Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Apr 25, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Sanyo Xacti VPC-T700 Digital Camera Logo
236 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
