Question about Roper Washing Machines
Roper washing machine RTW4440XQ, my mom sets the load for medium and when it is going to fill with water the second time before rinsing it only fill with water as if it was a small load. Does it have a feature that saves the consumption of water?
All new washing machines in the US, as of 2011, must comply with Govt energy regulations. Save water & Destroy your clothes! This model has 2 pressure switches. The main one (on the left) controls the wash water level, and the rinse level switch (unseen, mounted to the right, controls the rinse water level. BOTH ARE ADJUSTABLE ! First - UNPLUG THE WASHER ! Tilt the control panel back. You will see the two pressure switches. In the center of each is a silver adjustment screw going into a white plastic plunger. Using a 3/16" socket or nut driver, turn the screw on the RIGHT SIDE pressure switch clockwise until it is almost all the way in to the white plastic plunger. The next step is a little trickier. Being careful not to touch any wires, Plug the washer in, Set the water level to HIGH, and start the washer . Raise the Lid, and observe the incoming water. It will stop when the pressure switch is satisfied - but the water level will be rediculously low. As you did with the Right side switch, adjust the LEFT side switch the same way - only 3-4 turns at a time. After each adjustment, push the white plunger in and it will begin to fill again. When it stops filling, check the water level - you may have to repeat this step 3 or four times, until the water level is 3 - 4" below the white plastic guard on the tub. That's it, Unplug the washer again, tilt the control panel back down & lock it in place. Plug the washer back in, lower the lid & let it run through the cycle. This repair will probably void your warranty, and is not recommended to ANYONE who is not familiar with tools, machinery and electricity. To those who can, **** the torpedoes and full speed ahead ! To those who can't, show this to your repairman. The advantages are 1- Cleaner clothes 2- Less damage to clothes 3- Less wear & tear on the machine, as it doesn't have to work as hard moving the load in too little water.
Posted on Nov 02, 2011
  • Richard Conti Nov 02, 2011
This is a pos washer I have the same problem it probably because they went "energy efficient" what a load of bull
Posted on Aug 22, 2011
    Scholar:
  • 142 Answers
That sounds like there might be something inside the tube that runs from the (outside) tub to the level switch. The switch has a very small hole where the hose connects; corrosion can partially block that little hole and prevent free air movement.
Posted on May 24, 2011
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Dec 04, 2017 | Roper Washing Machines
Rinse cycle only fills halfway
alot of newer machines do that. water saving feature
Dec 04, 2015 | Roper Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Where is the reset button on Roper washing machine top load water fills but nothing else happens
try to turn the timer dial to rinse and spin, and then see if the water will drain
Jul 07, 2011 | Roper RAS8445KQ Top Load Washer
Will not fill or rinse on the cold water setting
sounds like faulty fill solonoid valve,,you can check it with multimeter if your handy...
Oct 03, 2009 | Washing Machines
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
809 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
