Power and restart led
I have IBM P4 d845
i have mix up its Power and restart let leed will You help me how to fix it?
  • 185 Answers
No comments
Posted on Aug 15, 2008
Need IBM motherboard 29R8260 front panel controls
John,
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
What you need is a Front panel header pinout.
This I do not have. What I do have, is a simplistic method that may allow you to find out, what the pinout is.
http://www.ebay.com/itm/IBM-ThinkCentre-M51-29R8260-Socket-775-Motherboard-w-P4-3GHz-SL7PU-/390456414497?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D15%26pmod%3D260995444535%26ps%3D63%26clkid%3D1437936870868306373&_qi=RTM1062688
Looking at the Hardware Maintenance Manual for the ThinkCentre M51, (It also uses this mobo), the Front Panel header is to the right of the Ram Memory slots. (Processor to the left, Ram Memory slots at the Top)
Looking at the Ebay link, there are three views available. Click on the middle view. In the view photo the Front Panel header is the black rectangle below the Yellow ram memory slots.
Two rows of pins.
Power Supply plugged into power, use an LED light with two wires.
Go across the top row, and touch the first set of two pins next to each other.
No? Go on. Touch the next set of two pins. I'm willing to bet the third set of two pins is the Power On switch pins.
(Could be mistaken, however)
The contact made should be brief. The Power On switch is a Momentary Contact Switch.
Once the Power Supply comes on, wait a minute, then start testing the other pins.
LED light blinks? You have the HarDDrive activity LED pins.
LED light stays steady? You have the Power On LED pins.
Be aware however, that there may be 3 pins for the Power On LED.
Two Positive ( + ) pins, and one Negative ( - ) pin. This is for a dual color Power On LED. (Turbo mode/ Regular mode)
This would mean touching the first pin, or second pin, in the set of 3 pins, and the last pin in the set.
Computer restarts? You have the 2 pins for a Reset Switch.
(Do NOT touch the Power On switch pins again, or the computer may restart)
Not what I would like to state. Would like to state the exact pinout.
Perhaps if you get this figured out, you might take the time to post the pinout. Crude is fine, I can 'clean it up'. This way 100's to 1000's of people may be able to use your findings. Think how many people you would help.
Regards,
joecoolvette
Aug 19, 2012 | Computers & Internet
I HAVE IBM D845 bios update eror
hi,
if you mention your IBM model number i can easily help you by giving the driver. Anyway plz follow the link to download the BIOS driver
http://www.firstload.com/?ir=1&fn=d845+bios+free+download
thanks & regards
Anas K A
Jul 08, 2011 | IBM NetVista PC Desktop
IBM thinkpad turns on but screen stays black!!!!!
NO BEEP OR WHEN PUSH THE NUMLOCK CAN SEE THE LEED IF CANT SEE HAVE BROMPLEM WITH BORAD IGET YOU WHAT U DO IF NOT SEE THE LED SHURE AND REPLY ME
Mar 20, 2011 | IBM Computers & Internet
Cable wireing on motherboart
Try this picture, here.
Hope this helps you fix it.
Jan 17, 2010 | ASUS P4XP-X Motherboard
ASUS P4-533 won't power up.
Please disconnect all the connectors and put them one by one and try following DYI
1.Refix the connectors and the check the power is coming.
2.If the power is coming in the machine and the fans are moving then the issue is with the RAM refixing open the cabinet and then refix the RAM module and it will work.
Feb 19, 2009 | ASUS P4-533 Terminator (terminator p4)...
I need to know front panel pinout values for IBM NetVista 49P15
THE VENDOR HAS THE PIN LAYOUT AND SOME OF THE PLACE WHERE YOU DO BUSINESS WILL HELP WITH GETTING YOU THE DIAGRAM PAPER WORK.
ROD
Feb 16, 2009 | IBM (33P0825) Motherboard
Power Supply Problem with -5V
Get the original power supply for that mother board, don't save money and don't fool around with the computer like that!!
Dec 18, 2008 | Computers & Internet
Desktop won't start.
Try to replace the power supply with another known working power supply from another P4 desktop and then reconnect your wires from the front panel led lights, changing them around until they are in the correct position. I had an almost similar problem and I did the above, it is working now. All the best ! sirjohn
Oct 13, 2008 | Intel Desktop Board D845WN Motherboard
Connection to Motherboard P4IBMS
You can download a PDF of the manual here:
http://www.ecsusa.com/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=74&areaid=2&LanID=9
I have blown up the image for you to see it easier:
good luck
steven
Sep 17, 2008 | Computers & Internet
My Asus mobo P5ld2 cant turn on
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Apr 12, 2008 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
