Question about Samsung WF203ANW Front Load Washer
Samsung washing machine wf 203 ans xac door will not lock
  • 1294 Answers
SOURCE: Samsung washer parts
Try these sites: they should also have toll free numbers.
espares.co.uk
RepairClinic.com
AppliancePartsPros.com
Posted on Apr 10, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
  • 83 Answers
SOURCE: Dead LG WF-T8016TP washing machine
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
Posted on Sep 16, 2008
  • 958 Answers
SOURCE: Washing machine door lock problem
hello nesbit,
i think you could have a problem with the pause button, it is what it is doing, pausing the machine, un locking the door so that you can add clothes or what ever. could be that the button is triggering the signal while vibrating during wash cycle.
take a closer look at the buttons, feel if you have this clicking feeling that all buttons should have. compare the other buttons as you press them.
you might need a whole touch pad to replace if you will find the problem there.
tnx 4 using fixya,
drcool
Posted on Oct 09, 2008
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
Samsung front load washer leaking from boot seal.there is no rip or tear can itbe repaired.WF203ANW/XAC
Make sure that there is no hair or grunge built up under the glass door. If any particles are in between the glass door and the deal, it will leak. If all of that is fine then the door seal should be replaced
Jan 18, 2018 | Samsung Washing Machines
Lg washing machine wf-sp950g de ( door error )
Hi Azlan.
de Door Error usually shows when the door lock either won't undo...OR The machine won't start after the door is closed.
Both these situations probably mean that the door 'Interlock' is faulty.
The interlock is the part of the door lock which prevents you from opening the door while the machine is working.
It's part of the electrical circuit and should only be serviced by a qualified technician.
Good luck
Nomess
Feb 04, 2015 | LG Washing Machines
Problem with Hotpoint Washing Machines Samsung
ND -not draining. There could be something is stuck in the drain pump or one of the hoses connected to it( normally a coin is stuck in the L-shapped plastic connector to the drain hose)if the system is clear,then I would replace the drain pump.
Nov 02, 2013 | Samsung Washing Machines
Samsung WF-R1061 washing machine repeatedly trips
does it show an error code ? when it trips what is the washer doing filling water or spinning etc ? does it work on other settings like spin and drain with out tripping. ?
May 27, 2017 | Washing Machines
Lg washing machine WF TS 800 after selecting quick wash, machine will delay washing and says DE, washing will then stop.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
Lid open error in WF-T6517TE
it could be that the magnet in the door lid has slipped or fallen out. I stuck a new magnet on the rim of the machine and the dE eror message went away
Dec 13, 2009 | LG Washing Machines
Operating of samsung WF-B1061 washing machine
You can download the manual direct from samsung just go to their site type in your machine and download.
May 22, 2009 | Samsung WF317AAG Front Load Washer / Dryer
Samsung WF203ANW Front Load Washer Logo
78 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
