NEC NW-892 8kg washing machine wont pump water out or spin think its the pump want to know where in Newcastle Australia I can get parts for it. Thanks
4 Suggested Answers
SOURCE: NEC 892 blocked pump
For most blocked-pump issues, the true problem is something like a sock in the outer tub, over the tub outlet.
If the cloth has slipped into the pump hose completely, or into the pump body, you will have to remove the pump hose from the bottom of the outer tub and try to fish the material out of either the tub, the hose or the pump body. Complete removal of the pump may be necessary to accomplish this task.
For top-loaders, wherein you can't fish the clothing through the tub outlet, one can open up the unit, and remove the outer tub cover, and fish the offending bit of clothing out with a creatively-shaped length of coat hangar.
Posted on Sep 08, 2009
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
SOURCE: washing machine nec nw-652
i am having the almost the same problem with what i have, if it is turn, the water will just keeping on pouring in non stop, it does matter wether it is wash, rinse, dry or spin the water will just keep on pouring in at all time, it is not a good machine at all.
Posted on Oct 15, 2008
How to fix NEC NW-961 6kg
Good to know the washer is working fine.
You may also benefit from running the washer empty with a cleaning agent like this
http://www.rubbedin.com.au/Product/17/The-Magic-Range/Washing-Machine-Cleaner-
Apr 27, 2014 | Washing Machines
Tip
Your washing machine washes but wont drain and spin
to start let us remeber that a washer will not spin unless it detects that all water has been pumped out most times its the water pump but some times its a block in the hose. we here at sonic boom electronics australia.have seen the hose blocked by small socks small coins and even small nickers it can also be caused by currosion around the solinoid motor an ohms test to see if the motor is burnt out is the best way but if you dont know how to do such a test this is a good start guide
cheers
sonicboomelectronics@hotmail.com
on Apr 21, 2010 | Washing Machines
My NEC NW-81R top loader when it turns on does not make the usual introductory series of beeps and is stuck at a spin cycle but won't start. The only button that works is the power button...any...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 24, 2011 | Washing Machines
I am having a problem with my NEC NW752 Washing Machine. It runs through the cycle but will not drain the water. There were no kinks in the hose and when we hooked another washing machine it worked fine....
chances are that your daiwood / nec unit has a bad drain pump or perhaps the unit is not level or the drain hose is to high for the pump to pump out the water lastly
if you remove the front of the unit where the pump is located as you will see in the link I sent you there is a trap that may need to be cleaned out it has a hand screw cap that you can open and clean try that first before replacing the pump i sent you in the link NEC WASHING MACHINE WATER DRAIN PUMP NW752 NW891 NW652 NW 891 NW 81R eBay
Mar 04, 2018 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
The NW - 891 NEC washing machine does not finish the third cycle or drain?
Our nec washing machine nw 891 leaks water into drum when finished , I think it needs new washers, is this hard to do?
Aug 06, 2008 | Washing Machines
Washing machine nec nw-652
Sep 09, 2007 | Washing Machines
Washing Machines Logo
296 people viewed this question
Top Washing Machines Experts
