Question about Garmin GPS
My Garmin GDB 50 MSN Receiver/Car Charger lost the piece on the tip to connect it to the cigarette lighter. Can I purchase the replacement part?
    President:
  • 1,514 Answers
You can buy a complete charger by going to https://buy.garmin.com/shop/shop.do?pID=8526
Click on "FIND A STORE" and select your country.
A cheaper option would be to go to a car accessory shop and buy a plug for cigarette lighter accessories. Take it apart and use the tip out of it.
Posted on May 25, 2011
  • mrobins49 May 17, 2014
    Depending on the model GTM20, parts can be found at GPSNSTUFF.com and cost will be lots cheaper!
    Sorry about typo but the same parts kit will work with the GDB 50.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Parts kit is the cheapest way to go. Go to GPSNSTUFF.com and purchase GTM 20 repair kit. $10-15
Posted on May 17, 2014
Garmin says low battery and now will not work in the car. Does this Garmin have a battery inside the unit that I have to replace?
There is a battery in the satnav but it's not user replaceable. It can only be replaced by returning it to Garmin. Before sending it away to replace the battery you could check the following;
  • Have you the satnav connected to the charger?
  • If it's connected to the charger is the cigarette lighter socket working. You can check by plugging in another device to see if it works
  • If the cigarette lighter socket is working and the battery of the satnav is not charging it's possible that the fuse in the plug, that goes into the cigarette lighter socket, is blown.
To change the fuse;
Unscrew the ring that's at the end of the plug and the plug comes apart. Be careful not to lose the silver coloured tip. When the plug comes apart you can take out the fuse and get a replacement at any car accessory shop or a shop that sells garmin satnavs.
If you have to return your satnav to garmin you can find their contact details at http://www.garmin.com/garmin/cms/home/support/supportcontact
May 23, 2011 | Garmin nuvi 255W GPS Receiver
My car charger will not charge battery in garmin Nuvi 760
The fuse may be gone in the charger. There's a ring, near the silver tip, of the plug that goes into the cigarette lighter. If you unscrew the ring the plug will come apart. Take care not to lose the silver tip as it may fall out. Replace the fuse and it may solve the problem.
Feb 28, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
I need to buy a plug for car . It is not charging tne GPS
You can get accessories including the car charger from http://www.gpsnow.com/Garmin_nuvi_255_Accessories.htm
However it's likely that if the car charger is not working that the fuse is blown. The fuse is in the plug that goes in the cigarette lighter socket. To get at it unscrew the ring at the end of the plug. Be careful not to lose the small metal tip. When you unscrew the ring the plug comes apart and you'll see the fuse. You can get replacement fuses at any shop that sells garmin satnavs or car electrical accessory shops.
Before changing the fuse make sure your cigarette lighter socket is working by testing it with the cigarettel lighter or some other accessory.
Jan 14, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi will not charge when plugged into car charger but will charge when plugged into house charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Dec 17, 2010 | Garmin Nuvi 770 Car GPS Receiver
I have a Garmin Streetpilot c330 with a car charger but it doesnt charge the battery for some reason so now my system is dead, is there anyway to fix this problem?
Check the fuse in both the cigarette lighter socket on the car and the cigarette lighter adapter on your power cord, the tip should twist off and this should expose a fuse.
Hope this is of some help.
Ed
May 05, 2009 | Garmin StreetPilot C330 GPS Receiver
Lost cigarette lighter adaptor
I purchased a replacement. Thank you.
Feb 07, 2009 | Amcor 3900 GPS Receiver
The part that goes into the cigarette lighter broke on my Garin Nuvi. When I pulled it out, the small metal pieces, and a little glass tube fell out. How do I put it back together?
The glass tube is the fuse. There should be a spring and threaded metal barrel with a metal tip that slides through it. Look for these (4) parts.
The spring goes in first, followed by the glass fuse and then the metal tip should pass through the metal barrel. Screw the metal barrel with the tip on the end over the fuse. When you press on the tip, it should push in a little and spring back out. If you lost the pieces, you'll need to purchase another charger.
- Jim
SHARCNET-USA
Dec 16, 2008 | Garmin nuvi 255W GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Recharge
The car charger worked fine in my car, but if it doesn't work for you, you can always charge it using the USB cable with your computer.
Dec 25, 2007 | Garmin StreetPilot c550 GPS Receiver
GPS Logo
496 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
