Question about Scan Computers Brother MFC Color Inkjet Flatbed Printer
Cant get my brother mfc 235c to scan, it wont connect o my pc?
SOURCE: Brother MFC-465CN wont print
I had a similar problem, and it was due to the IP address not being properly set during installation. (Note, I installed it as a network printer. If you installed it as a USB printer, this won't work) Try this:
Select Start->Printers & Faxes, a window comes up, hopefully your Brother printer is one of the printers.
Right-click on the printer icon and select properties
Select the "Port" tab in the window that comes up
One of the entries should say "Standard TCP/IP Port". Click on that entry and click the "Configure Port..." button, a window will come up.
In the "Printer name or IP address" field, you may have a name here instead of an IP address. (Mine was "BRN008077E21669") Change this to the IP address for your printer. You can get this by navigating the menu on the printer (Under LAN->TCP/IP). I changed mine to 192.168.1.80, since that's the address I configured my printer for.
Hit OK and Apply in the open windows and hopefully you wil be in business. Good Luck!
Posted on Sep 27, 2008
  • 320 Answers
SOURCE: Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Posted on Jan 17, 2009
  • 159 Answers
SOURCE: Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Posted on Dec 24, 2009
SOURCE: Brother MFC-7840W Printerwill only give me Scan To FTP option now
i had the same issue - was previously able to scan to a number of different formats, then switched modems, providers and then only the scan to ftp option came up.
took me about an hour to figure out the solution, but now it works
for windows users: * go to your control panel * go to the scanners & cameras section * your printer/scanner should show up here * right click on it and select 'properties' * select the network settings tab and then -- enter in the correct ip address here OR -- specify your machine by name (enter in name here)
hope this helps!
Posted on Jun 21, 2011
SOURCE: I dont know how to
Use the Scan to File feature from the ControlCenter
>Place the document to be scanned on the scanner glass (Flatbed) or Automatic Document Feeder (ADF) depending on the model of your Brother machine.
>Open the ControlCenter by clicking Windows/start-> (All) Programs ->Brother-> XXX-XXXX (Where XXX-XXXX is the model number of the machine)-> ControlCenterx.
>Double-click on the ControlCenter icon located in the Task Tray to launch the program windows.
>On the SCAN menu, click the File button.
>The document will now scan and be saved into the specified location in PDF format, according to the setting you made in the Software Button tab of the Scan to File configuration window of the ControlCenter.
Use the Scan to File feature using the Scan key on the Brother machine
>Make sure that the ControlCenter has been launched and loaded in the Task Tray near the system clock.
>Place the document to be scanned on the scanner glass (Flatbed) or Automatic Document Feeder (ADF), depending on the model of your Brother machine.
>Press the Scan key on the Brother machine and select Scan to PC -> File, or Scan to File.
>Press OK.
>Press Start , Mono Start or Colour Start to begin the scanning. The document will now scan and be saved into the specified location in PDF format, according to the settings you made in Device Button tab of the Scan to File configuration window of the ControlCenter.
Posted on Jul 27, 2011
I miss driver files of my printer ( brother mfc-235c)
Hello
Here is the link to download driver for MFC-235c http://welcome.solutions.brother.com/bsc/public/as/au/en/dlf/download_top.html?reg=as&c=au&lang=en&prod=mfc235c_eu_as
You need choose the operating system you want, language and press search button
Hope this help, if so do rate the solution
Jan 04, 2011 | Office Equipment & Supplies
Hi i have a printer (brother MFC-235C). I changed
No there's no specific drivers for windows 7 either 32 bit or 64 bit, it'll automatically install the device with the default drivers.
details here
If there's a problem with your cartridge or cartridge ink level indicator, then you better clean the cartridge contact points and the contact points on the printer.
Good luck
Thanks for using FixYa.
Jun 25, 2010 | Office Equipment & Supplies
Need to link my brother printer mfc-235c to my pc using usb but have not got the disk to load sofeware on to the pc
usb printers have their drivers on the unit, when you connect the usb printer to pc, windows automatically detects the printer and install its driver
Oct 18, 2009 | Office Equipment & Supplies
Cant install
Driver Download Page for MFC 235c:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc230c_us
Copy and paste the link in your address bar.
Jun 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Changed my computor & have lost instaltion disc
I fixed the problem thanks. Unfortunately I don't know how so can't tell you!
Jun 05, 2009 | Brother MFC-8440 All-In-One Laser Printer
Need to refill printer cartridge
check it out
http://www.printcountry.com/refill_instructions.asp
http://www.refillinstructions.com/
http://www.bs-print.co.uk/brother.asp
Feb 02, 2009 | Office Equipment & Supplies
Nov 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-260C How do edit phone numbers set up in short dial
i have misplaced my disc for installinig my brother MFC-235C
MFC-260C. any help with an answer to installing my printer would be much appreciated. thank you, tania
Aug 20, 2008 | Brother Office Equipment & Supplies
Brother MFC-235C three in one
you have to insert the driver cd in the cd rom and follow the instruction, if you dont have the cd then download it from the manufacture website
Aug 12, 2008 | Computers & Internet
I cant scan
You have to connect the mfc directly to a USB port of your computer. DO NOT use a hub.
The mfc uses the XP buil-in scan driver.
Did you install the whole mfl-pro suite? Use paperport to do scanning from your pc.
Jan 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Scan Computers Brother MFC Color Inkjet Flatbed Printer Logo
165 people viewed this question
Top Scan Computers Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Scan Computers Office Equipment and Supply Expert? Answer questions, earn points and help others
