Question about Video Game Consoles & Games
I need the driver for the nintendo wi-fi connector
  • 1,188 Answers
Here you go:
http://www.nintendo.com/consumer/downloads/usb/Nintendo_WFC_USB.zip
Just in case you need it:
For complete setup instructions:
Wii: http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=usbInstall
DS: http://www.nintendo.com/consumer/wfc/en_na/ds/connect.jsp?entryId=usbInstall
Posted on May 25, 2011
How can i connect my computer to my nintendo?
https://www.nintendo.co.uk/Support/Nintendo-3DS-2DS/Connecting-to-the-Internet/Connecting-using-a-Nintendo-Wi-Fi-USB-Connector-/Connecting-using-a-Nintendo-Wi-Fi-USB-Connector--243609.html
Mar 04, 2015 | Nintendo 3DS XL - Blue/Black
How do you connect to the internet on a dsi using a usb cord?
There is no USB cord, you will need a Nintendo Wi-FI USB Connector. http://en.wikipedia.org/wiki/Nintendo_Wi-Fi_USB_Connector That will explain how to obtain, and use the Nintendo Wi-Fi USB Connector.
Jun 22, 2011 | Video Game Consoles & Games
Ok i lost my disc to install the nintendo wi-fi connector usb and now i really need the file on the disc so i tryied googling my problem and i found a customer support page for just this but for some...
The download for the drivers can be found here (http://www.nintendo.com/consumer/downloads/usb/Nintendo_WFC_USB.zip). You should be able to simply open them with the Zip extractor built into windows, or simply download 7Zip to extract it. (http://www.7-zip.org/download.html)
Mar 20, 2011 | Nintendo Wi-Fi USB Connector for DS/ Wii
Just opened new acer aspire 5734Z and the battery says plugged in, not charging.
Hello
The battery seems bad, need replacement, if the laptop is new then you have the opportunity to avail warranty of the system,
Good Luck,
hope it helps, if so do rate the solution
Dec 26, 2010 | Nintendo Wi-Fi USB Connector
What does error code:51099 mean
Error Code: 51099
The only access point within range of your Nintendo DS is not configured or is not compatible with the Nintendo Wi-Fi Connection (such as those found in many Hotspots).
Where are you trying to connect from?
1. Wireless Home Router (please scroll down)
2. Nintendo Wi-Fi USB Connector (click here)
3. Hotspot (click here)
Using a router:
1. Please make sure that your router is not on our list of incompatible routers. Click here to view the list and locate your router (if available). If it is listed as "not compatible," then it appears your router will not work with the Nintendo Wi-Fi Connection. Consult the compatibility chart for recommended routers, or consider purchasing a Nintendo Wi-Fi USB Connector. If your router is not listed as being incompatible, please proceed to step #2.
2. Ensure your router has the latest firmware installed. Visit your router manufacturer's website and look for any updated firmware that may be available (these are typically found under "downloads" or by searching for your particular model number). Contact your router manufacturer for additional assistance.
3. Make sure that your network's name (SSID) matches exactly to what you have entered in the Nintendo DS.
1. Log in to your router using the default IP (consult the router?s owner?s manual for assistance).
2. Look for the section for SSID (typically in the "wireless settings" area).
3. After you find the SSID (network name), verify in the Nintendo Wi-Fi Connection Settings of your Nintendo DS that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
4. Check Nintendo's router info for special notes, if available, for your router.
1. Click here to go to our Wireless Router Configuration page.
2. Use the drop-down box on the left to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing such things as the Transmission Rate.
5. Your router may not be assigning an IP address to the Nintendo DS. Try manually assigning an IP address to your Nintendo DS.
1. The first thing you'll need to do is find out what IP address your router is using. To do this:
1. Click the "Start" button in the lower left-hand corner of your computer.
2. Click "Run."
3. Type "cmd" into the box and press Enter.
4. Type "IPCONFIG/ALL" and press Enter. The IP address displayed of the PC will be displayed.
The IP address you going to assign to the Nintendo DS must be 10 digits higher than the PC?s. (e.g., 192.168.1.100 becomes 192.168.1.110)
2. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this, please click here.
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Using a Nintendo Wi-Fi USB Connector:
* Does the Blue Wi-Fi registration tool icon appear in the system tray of your PC (typically this is found in the bottom right-hand corner of your computer screen, near the clock)?
1. Yes. If the connector has been inserted very recently, it may take several moments for it to establish a connection. Retry.
2. Yes. If the USB Connector is inserted directly into the PC, trying attaching the plastic extension cable that came with your USB Connector. Getting some distance between the PC and the USB Connector may help the signal strength.
3. No. Is the software installed? Is the USB connector inserted? Restart the PC, and if it still does not appear, we recommend uninstalling the software and installing the latest version. Click here to get the latest software for the Nintendo Wi-Fi USB Connector.
4. Yes, but it's gray. Is the USB connector inserted? Right-click the registration tool icon and choose to run the registration tool. If it does not respond, restart the PC. If it still does not respond, we recommend uninstalling the software and installing the latest version. Click here to get the latest software for the Nintendo Wi-Fi USB Connector.
Oct 24, 2010 | Computers & Internet
Nintendo Wi FI connection settings
read your manual...and one thing more you should have a nintendo wi fi connector connected to your pc..otherwise you wont suceed
Feb 28, 2010 | Nintendo DS Lite
Im using Wi-Fi USB connector for internet connetion, but it keep show up error code 52140, not able to connet... even my USB connetor is showing the running man mark on my computer?
Try this..
1. On the computer with the USB connector, get a command line (start -> run -> cmd) and type the command ipconfig /all
2. Normally it will show multiple DNS addresses.
3. Now connect your Nintendo USB connector.
4. Go to your network connections (usually under control panel) and right click the USB devices.
5. Under the general tab, look for Internet TCP/IP, highlight it and click properties.
6. Click Use the following DNS Addresses and enter the two addresses from step#2.
Nov 02, 2009 | Nintendo Wii Console
Wii wireless connction has error code 51040
rror Code: 51040 Please try the following troubleshooting for the Nintendo Wi-Fi USB Connector
  1. Verify that the Nintendo Wi-Fi USB Connector is installed correctly and that the PC is turned on (the USB Connector will not work while the PC is turned off).
  2. Try our interference troubleshooting steps.
  3. Are you using any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.)? If so, you may need to add the Nintendo USB Registration Tool software to a list of "allowed" programs or "exceptions." If this is unavailable, you may need to disable yousecurity program before the Nintendo Wi-Fi USB Connector can access our servers. See Nintendo Wi-Fi USB Connector "Firewall troubleshooting" for more information.
  4. Try uninstalling the Nintendo Wi-FI USB Connector software, and installing the newest version. To get uninstalling instructions and the latest version of the software, please click here.
Nov 29, 2008 | Nintendo Wii Console
Trying to connect to wifi usb connector and keep getting error code 52203
I'm assuming you are talking about the nintendo DS. Here is the info on that error code straight from nintendo:
Error Code: 52203
The Access Point you are attempting to connect from is not connected to the internet or a firewall is blocking traffic necessary for connecting to Nintendo Wi-Fi Connection. What to do will depend on where you are trying to connect from: What to do:
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Verify that your router is connected to the internet when attempting to connect to the Nintendo Wi-Fi Connection. If you are not able to access the internet on your computer, then there is a problem with your internet connection. Contact your Internet Service Provider (ISP) for more information.
  • America Online (AOL) broadband users may experience difficulties when attempting to connect to the Nintendo Wi-Fi Connection. Please contact America Online for assistance.
  • If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls and the Nintendo WFC, click here.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Connecting from a non-partnered Hotspot:
  • The access point at the Hotspot may not be experiencing problems. Ask the staff on site if their Wi-Fi network is up and running.
  • If the Hotspot's access point has a built-in firewall or other security that interferes with the necessary transmissions from the Nintendo DS, then the access point will not be compatible with the Nintendo DS.
  • Try another Hotspot. To search for known Hotspots in your area, click here.
Jul 16, 2008 | Nintendo Video Game Consoles & Games
Video Game Consoles & Games Logo
53 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
