Question about Samsung RS277AC (27 cu. ft.) Side by Side Refrigerator
The LED display is blinking a refrigerator temperature of 36 degrees. The fridge is not actually getting to the proper temperature.
  • 159 Answers
SOURCE: Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
Posted on Aug 04, 2007
BIKER T
  • 909 Answers
SOURCE: The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Posted on Aug 17, 2007
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
I have RS2555 in same problem.my warranty is expired and Samsung hooked me up to an technician who asked for 300.00 for labor plus parts and tax, what a rip off!!I I called my Canadian friend who's a technician and I was told to POWER OFF the RS2555 for 24 hrs.both doors MUST open and take out all drawers,he said ,it is 90% the ICE blocked the cool airflowing,so if ICE melted,all will return to normal.
It works after I did what he said.share this and hope can help some one with same problem!
Posted on Mar 26, 2008
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
  • 531 Answers
SOURCE: Fridger temperature selector does not reach the set temperature
check if you have frost build up in the freezer
Posted on Apr 07, 2009
I have a mini fridge the 150 can refrigirator and I have it at max temperature but I still think it's not cooling enough
Have you checked for the actual internal temp of refrigerator - should be 36-39 degrees.
Sep 18, 2015 | Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
How do I set the temperature on a true refrigerator model GDM-26EM?
40 degree is a perfect temperature for produce if its lower that stuff will turn brown. Maybe you thermometer has failed. Go to the food store and get a red stick and put it in there. Then adjust with that temperature indication. Hope this helps and good luck.
May 09, 2014 | True Refrigerators
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
I have a samsung refrigerator model RS253BASB. The freezer stopped working. The fridge is exactly 4 years old. Bought it new at Best Buy. The display shows the temperature being at -10 degrees but it...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172308&diagram_id=1337099#d1337099
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 19, 2010 | Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Proper temerature for refrigerators and freezing compartments
hi thanks for the question the best temp to have in fridge is 36 degrees and in freezer 0 and minusfor good ice cream thanks the appliance doc
Sep 27, 2008 | Candy CPCA270FFK Bottom Freezer...
Refrigerator is not cooling, but freezer is working properly
Usually it's because it's not defrosting. If there is frost buildup on the back wall of the freezer, it's a defrost issue. Most of the time these fridge have a defrost issue, it's because the defrost heater is bad. If this is the case you can get by for a while by manually defrosting the fridge. Take everything out, turn it off, leave the freezer door open and let it sit for 24-36 hours.
Jul 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Jun 06, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Samsung RS277AC (27 cu. ft.) Side by Side Refrigerator Logo
22 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
