Question about Fedders A7DH65B2A Dehumidifier
Lites up but does not run - Fedders A7DH65B2A Dehumidifier
    Brigadier General:
  • 4,736 Answers
First check the water collection bucket, to make sure it's properly seated and making contact with the safety switch. Also check the humidity level you have the unit set on. It may be to high for the humidity level in your house. Reset the humidity level to either minimum or if you have an LED screen 45%. Remember, the lower the setting, the more humidity will be removed.
To do an in home test of the unit, move it to a bathroom. Turn the unit ON and set the humidity level to it's lowest level. Turn the shower ON hot enough to generate steam. Do not turn the bathroom's exhaust fan on. As you exit the bathroom, close the door. Wait 15 to 20 minutes and turn the shower OFF. Allow the dehumidifier to run for several more minutes, before checking the water collection bucket for water. If you find any water in the bucket, it's working as it should. If not, it's time to replace the unit. Under most circumstances, I would suggest possibly repairing it. But, Fedders is out of business and replacement/repair parts are a scarce as hen's teeth.
Hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 24, 2011
Red Lite is flashing, unit will not turn on
if the red light is flashing this means theres a fault , most common fault on these are water catch bucket is full or not seated back correctly
Aug 24, 2015 | Amana D950EP Dehumidifier
Have a dehumidifier, Delonghi DE500P. Unit operates but no water collecting in bucket.Level set to 35%. Can freon be added to recharge?
the short answer is yes , but id caution you on the need too first?
first check the basics:
bucket full lite not on (blinking)
filters clean ?
both fan and compressor inside running (sometimes the fan runs but the compressor does not?) listen carefull for them both?
if your unit needs recharged odds are it's not financial feasible to do so , first you have to fix cause of gas leaking out ? what ever that is ? then you need to add service ports and finally you need a gas charge , this would or could cost hundreds of dollars , a entire new unit is less 200 bucks unless you do all this work your self , but id tend to think if you had all the tools and knowledge to do that youd not of asked here in the first place
Jul 21, 2015 | Dehumidifiers
Unit keeps cycling off and on with the "bucket full" light blinking
It appears as if the water may not be flowing through the hose.
* When you use a hose the unit must be located near the drain. If the hose is to long the water will not flow freely and cause the water to back up in the hose triggering the bucket full.
* If the unit is lower or the hose runs up hill even the slightest incline will cause the water not to flow backing up to the machine
* Hose must remain flat and in a down hill flow to the drain if you are running a longer hose than recommended. If you are have a long distance to run the hose elevate the dehumidifieer by placing it on a stand, milk crate, anything that will hold the unit. Be sure it is large enough and strong enough to support the unit to prevent it from falling. This will help siphon the water from the unit and prevent any water to back up the unit.
* If your using an old hose make sure there are no kinks and water flows freely through the hose. Any kinks or type of pinch in the hose will cause the water to back up
I hope this helps resolve your issue. This is the most common mistake when using a hose.
Nov 30, 2013 | LG Dehumidifier LD650EAL
Ihave a comfort aire BHD-301. when i turn it on the filter lite keeps blinking and the filter is clean. is there another filter besides the one on the side?
No, there's only one filter. So be sure that you reinstalled the filter properly, so that it is making contact with the filter switch. If that checks out OK, turn the unit OFF & unplug it for 15 minutes.
After the time has elapsed plug the unit in and turn it ON. Hopefully, during that timeout, the electronics reset and reverted back to the original factory settings, If so, you can now set the controls as you desire.
I hope this helped you and thanks for choosing FixYa.
Jul 24, 2011 | Comfort-Aire BHD-301 Dehumidifier
Drained water from unit and unit still shuts off with lights still flashing.
pull plug wait a few minutes lite comes from float switch or wet switch make sure its not hung up or wet.
Jul 03, 2011 | Sharp CV-P10MC Dehumidifier
It was working fine, I shut it off and the next time i turned it on nothing happened. None of the front lights lite up. like a fuse was gone or no power. I checked all the obvious including the small fuse...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 22, 2011 | Kenmore 54501 Dehumidifier
Compressor won't kick on
This usually means that the capacitor is bad and needs to be replaced, it is a small round device that is either near the compressor or in the control panel area, on the side of it, it will tell you the "MFD" rating and the voltage, and that is the two numbers that you need to match. Be carefull, with the old capacitor, if it is shorted it can hold a electrical charge, even with no power to it, and can zap you, not fun :)
If this has been helpful, please rate the new guy :)
Contact me if I can help you any more.
Sincerely,
Paul
Apr 03, 2010 | Goldstar DH304 Dehumidifier
The bucket full light is on and unit will not run. Unit has hose adapter in use.
Look inside where the bucket goes in at the top right hand side is the bucket switch. Hold it in and start the unit. If it runs the arm on the switch must be bent SLIGHTLY until it makes contact with the button and the lite goes out with the bucket in.
Nov 16, 2009 | LG LHD45EL Dehumidifier
My 1 yr old Zenith ZD30 dehumidifier just stopped working all together. The bucket is empty and I checked the to be sure that a circuit didnt trip. Any suggestions as to what it can be?
The Zenith ZD30 is made by LG as many other brands are also. There is a fuse located on the control board. That may have blown. I have also had 3 LG units come into my shop with bad control boards. If the fuse is ok. Measure the ohms at the power plug L1 to Neutral, with the unit unplugged. It should read around 430 ohms. The ones with bad boards read real high. Hope this helps.
Rasske's Renewed Appliances
Oct 20, 2009 | Dehumidifiers
Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Nov 04, 2008 | Amana D530M Dehumidifier
Fedders A7DH65B2A Dehumidifier Logo
79 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Albert
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
