Question about Panasonic NNSD297SR 1200 Watts Microwave Oven
All the lights work on the microwave, but it will not rotate or heat, It shuts off after 3 seconds. Is it fixable? thanks. Carolyn
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: On for 2-3 seconds and shuts down with slight wire burning odor.
http://froogle.google.com is showing this model selling for as little as $100. But as a technician, I have never cared for the inverter models. As complexity increases...
Posted on Mar 21, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Stops working after 38 seconds
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter or a bad magnetron. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter or magnetron with him when he comes out to repair it. Might save you having it pulled into the shop.
Posted on May 10, 2007
MicrowaveSvc
  • 9098 Answers
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Bosch hmb5050 shut down after 30 seconds
It may be turning off because it is not heating, does it have the lights inside and the turntable both working?
Dec 10, 2012 | Bosch Microwave Ovens
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
Microwave heating for 20-30 minutes with no food. Does not work.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hgj
Jun 02, 2010 | GE JVM1630 Microwave Oven
Food still cold after cooking
Is this a combi oven? If it is not-and only a micro then there is no heating element. Try it on micro(if its a combi) with a mug of water for approx 30 seconds to test it. If its a combi-is the micro function still working?
Jun 21, 2009 | Emerson Microwave Ovens
Panasonic NNSD297SR 1200 Watts Microwave Oven Logo
32 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
