Question about Speed Queen AWS52NW Top Load Washer
Speed queen washer ( top loader) it's a "Marathon
4 Suggested Answers
  • 1294 Answers
SOURCE: I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Posted on Mar 06, 2009
  • 432 Answers
SOURCE: I have a newly installed 2nd hand speed queen
I seems the mixing valve is not allowing hot and cold to be mixed.
Posted on Nov 07, 2009
  • 3600 Answers
SOURCE: Hello. I have a commercial Speed Queen top load
try checking the where the water hoses connect that water valve is where the water is shut off, turn off the water facuet undue the hoses and look inside the valve does it have calcium buildup? or sand in it? if it does you will have to pull the water valve to clean it in order to get it to work correctly. Let me know if you need more help and thanks for using fix-ya.
Posted on Jul 01, 2010
How can i get the agitator off a speed queen modle number AWN412SP111TW01
If its a standard top loader there should be a cap you can pry off on top of agitator. Screw or bolt is under cap.
Nov 27, 2017 | Speed Queen Washing Machines
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Speed queen Marathon top loading washer- Water leaks into drum when not in use??? Shut off valves in the basement.
The problem is the water inlet valve has failed. There is a video on checking this at www.appliancehelponline.com/servicemanual.html it's a different model but the testing procedure will be the same.
Mar 28, 2010 | Speed Queen AWS52NW Top Load Washer
What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Jun 29, 2009 | Speed Queen AWS52NW Top Load Washer
  • Behind the door
Mar 06, 2009 | Washing Machines
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Speed queen top loader
You should be able to get a replacement agitator from partselect.com or repairclinic.com. look on line for an agitator however How old is the washer, would you give me the serial number.
T
Jul 27, 2008 | Speed Queen AWS44NW Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
308 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Charles T Nevin
Charles T Nevin
fta777
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
