Question about Schwinn Cycling
My daughter has a Schwinn Sidewinder 26" mountain bike. The chain keeps jumping from the rear sprockets to a smaller sprocket under power. I have noticed that the rear sprocket set "wobbles" side to side or inside out as the wheel turns. Also the outer rim of the rear wheel also "wobbles" a little. The rear wheel at the hub (axle) seems to be true. Can I realign the sprocket set perpendicular to the axle? How do I true up the outer rim? It is only 2-3 years old. Thanks a lot! Bob
    Brigadier General:
  • 8,546 Answers
It's loose on the hub. Special tools are required to tighten them. Bike Shops have them and will possibly perform the repair for less than the cost of the tools.
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
Then check the shifting...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Word to the wise: don't buy bicycles from anywhere but a professional bicycle shop. Box stores don't usually have the skills for proper assembly, setup or follow-up.
Posted on May 24, 2011
Chain keeps skipping while I'm peddling
This is usually the setting of the rear shift.
Check that the rear d?railleur is properly aligned when it is set to the middle sprocket in the cassette.
The chain must be fed exactly to the middle of the sprocket teeth
Aug 02, 2015 | Columbia Sportswear Columbia Trailhead...
How to adjust front derailleur on a shamano 050 ?
The front part is a bit tricky to change sprockets. I have a mountain bike with three sprockets, I also have difficulty with changing them. It all depends on the design of the changer. I am able to change from large sprocket all the way to the smaller but from the smaller sprocket to the second is okay but going into the third (large) sprocket is a real problem and no matter how hard an adjustment I've tried, it still doesn't want to go to the far end. Example, if it is in the smaller sprocket, it changes okay to the middle sprocket but it will not fully change in the larger sprocket because the cable doesn't fully push the changing bracket far enough to roll the chain on it. So, as with myself having same problem, I'd say, never buy a bicycle that doesn't change the front sprockets with ease. But while you have one of these three front sprocket bicycle, you have two options. Try and put the bicycle on a stand and adjust the changer's screws so that it can reach the far end where the large sprocket is, or in another case -where the smaller sprocket is, depending where your problem lies, the larger or the smaller sprocket). Remember that the air test is different to the road test. On the air test (bicycle on stand) the changer may be able to change sprockets but on the road the chain is heavily under tension and may not over-jump into the larger sprocket, but down-jumps into a mid or smaller sprocket quite easily. So, the best thing you can do is to not to apply force to the pedals to relieve the chain of any tension so that it can jump over the larger sprocket. But apply tension to the chain, such as 'accelerating', and it will not over-jump the larger sprocket with ease. However, if you change down to a smaller sprocket while 'accelerating', it usually changes without problems. The other option you can use is to sent the bicycle to a store and have it fixed there. Work is guaranteed and you can be sure your worries will be over.
Sep 01, 2014 | Mountain Shimano 050 Front Bike Derailleur...
On my shcwinn ranger the chain clicks and skips when it encounters difficult terrain such as a hill
It's likely that you need to replace the rear sprocket cluster due to chain wear. Over time the chain stretches, and then wears out the teeth of the sprockets (usually on the rear, but it can affect the front chain ring as well). If you look at the teeth on the rear sprockets, you'll probably see that they've got concave wear on the rear edge of them - this is probably the source of the chain slippage when under load. You should take the bike into your local bike shop and get them to take a look. Hope this helps. Ryes, Scott
Sep 04, 2011 | Schwinn Cycling
The chain is broken off the bike We bought a new one but need a diagram of how to weave the chain through Thanks
The chain goes from the top of the front sprocket to the top of the rear sprockets, between the rear sprocket and the top derailleur wheel and then between the upper and lower derailleur wheels. It then goes forward toward the front sprocket. The text sketch below shows the rear sprocket, chain and derailleur.I hope this helps.
(O
o)
(o
Aug 15, 2011 | Pacific International Pacific Evolution...
I have this Meridian Trike (Walmart purchase). I need a FREE WHEEL 16T SPROCKET to fit the rear axle shaft. the shaft is larger than 15mm & 5/8in ?? My local Bike shop could not help me with this odd...
Why not call a Schwinn dealer and ask if they can order it for you? You do realize that you void any warranty by altering you bike, don't you? But, if you don't care, look on the www.schwinn.com website and find a Schwinn dealer near you.
Jan 12, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
I had to take off the rear weel of my falcon apache mountain bike to get it in my car o travel from my grandparens home to mine but i cant get the back weel gear arm back on. how do i do this??
By the "gear arm" I assume you mean that part of the rear derailer that the chain zig-zags through. This arm moves in two ways. It moves in and out (toward the wheel and away) as you move the shift lever - which is how it changes gears, by moving the chain onto different sprockets (gears). It also moves forward and back (toward the front and back of the bike) under spring pressure. This forward and back motion is necessary to take up the slack in the chain when you are using the smaller sprockets (the smaller the sprocket, the "higher" the gear). When the wheel has been removed, this arm moves forward (under spring pressure) as far as it can to take up all of the slack in the chain. All you have to do is grasp this lever and pull it toward the back of the bike, allowing the lever and the chain to pass behind the sprockets (gears) as you pull the wheel back into it's position. You can safely pull this arm forward and back at any time without doing any damage. One more tip-- I find it a little easier if you first put the shift lever in a "middle" gear position. Then when you pull the wheel into place, you should aim to put the chain on a middle sprocket. You don't have to hit the exact correct sprocket as you can simply lift the rear wheel and turn the pedals forward (after installing the wheel) and the chain will move to the correct sprocket corresponding to the setting on the shift lever.
Good luck! Please vote if you found this helpful. Al K
Oct 14, 2010 | Falcon Cycling
How to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
May 03, 2010 | Cycling
My son just bought a 26" Huffy Jolt mountain bike. The rear sprockets spin freely when the pedals are cranked either forward or backward - - that is, there is no coupling to the rear wheel. What can I...
The plastic is to stop the chain from touching the spokes, it cannot cause this problem, either the chain is not on a sprocket correctly or the rear cluster(sprockets) is not working.
Some spray lube may help, but if it is new, take it back to the shop.
Apr 18, 2010 | Huffy Mens Mountain Bike - Crimson Red
I HAVE A SCHWINN 3 WHEEL ADULT BIKE. IT IS VERY HARD TO PEDAL UP A VERY SMALL GRADE. A FRIEND TOLD ME IT NEEDS A SPROCKET. CAN YOU HELP ME? I'D APPRECIATE IT.
Trikes are normally not made to ride much more then just around the block do going up even the smallest grade will be difficult. You could change the gearing but I suggest looking into adding a 3 speed hub if you are planning to ride more then a couple miles or live in a hilly area. You should contact your local bike shop.
Hope this helps!
Jul 13, 2009 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Installed new chain on nakamuru 21 spd now chain seems to want to skip when under load at rear sprocket
They are called coggs if they are at the rear, and sprockets at the front. What has happened is your old chain has worn dwn the metal on the rear coggs and there is'nt enough metal for the new chain to grab on to. You need a new coggset or a new freewheel
Mar 25, 2009 | Hawk Tony 's Huckjam Series 21 Speed...
Cycling Logo
278 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
