Question about Shure Audio Players & Recorders
Shure PR 56
Has a hum that I cant locate Checked out the cord and it seems to be OK
    Sergeant:
  • 243 Answers
Check the ground.
Thanks,
Nate
Posted on Aug 22, 2008
Rinse cycle not working
it seems like control board malfunction.
May 30, 2016 | Hobart AM-15 - Commercial Dishwasher -...
I have constant 24/7 humming noise (combi boiler i think) the boiler itself is not humming but seems to be in the pipes? mainly kitchen & upstairs, there is "hot spot" for the noise as you go...
If you turn the power off and it's still there then it's not anything electrical in the flat.. it could be transferred noise from another source. I would try locating the sound by listening through a tube to locate the sound more accurately. This method of sound source location is used by old fashioned mechanics listening for engine noises and is very good at finding them..
good luck !
Mar 30, 2017 | Water Heaters
Turn on benq pb6200 with new bulb all I get is humming and no led
same problem here. checked fuse, mainboard seems ok. nothing looked blown.
Jul 15, 2010 | BenQ PB6200 Multimedia Projector
Shure ULXP4 with handheld wireless mic tx indicator and hum
There are many things that could be causing these types of symptoms. Try calling Shure and asking for their Applications Engineering Department. They can help you troubleshoot your wireless.
Jan 22, 2010 | Shure ULXP4 Receiver
Unit powers up but just makes a load hum when input to pa batt*& cords are good
Try checking the solder joints where the output jacks are mounted on the circuit board of the receiver.
Aug 10, 2009 | Shure WIRELESS MIC SINGLE ANTENA MIC...
My wet end is leaking from the backside.
I have a executive 56 frame 4 hp water way motor - PF-40-2N22C. Wet end was leaking at shaft, had it fixed and now the motor won't rotate at all. shaft is free it just hums. Checked supply voltage and the voltage at the connector. All is ok, what do i do now.
May 21, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Vivitek 56 inch dlp projection is humming. why and how to fix
In my experience, the humming means your color wheel is going. The bearings inside the wheel are probably giving out.
My Vivitek started humming a couple of months ago and first I replaced the lamp.
Still hummed.
I read in other forums that humming is linked to color wheels and that seemed like where the noise was coming from.
I purchased a new wheel online and replaced it myself...
..no more humming, the picture is great and now I can listen to the movie again...not the tv!
Mar 17, 2009 | Vivitek V37655 56" DLP TV
Need cord for Shure 55S microphone
See the Shure website for the answer at:
http://shure.custhelp.com/cgi-bin/shure.cfg/php/enduser/std_adp.php?p_faqid=1012
Mar 09, 2009 | Shure 55SH Series II Professional...
Aprilaire 600
If the water is always on make shure the 24 volts is hooked up to 24 volts only when the blower is on. Some furnaces have a HUM terminal but make shure it is 24 volts some are 120 volts you must use the transfomer with the AP 600. You may may use a RP50 relay. The setting 5 or 6 is about the avg setting slowly turn down to see if it shuts off .Also make shure the damper is in the winter setting. Hope this helps
Jan 26, 2008 | Aprilaire 600 Humidifier
71 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
