Question about Maytag Freezers
My side by side refrigerator on the freezer side is dripping water at the bottom on to the coil. The coil seems to be making a sizzling sound and turning red is this ok
    President:
  • 670 Answers
There is a defrost heater that periodically turn on to melt the accumulated frost on the coil. The heater will warm the coil to about 45 degrees and a defrost thermostat should shut off power to the heater. The defrost cycle should only last about 30-45 minutes then the compressor should kick on. If you find that some items in your freezer are melting, or that the freezer is not maintaining temperature, then something is wrong. Hope this helps you.
Posted on May 24, 2011
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Water accmulation in the bottom of the refrigerator
Your drain line is probably plugged and causing the overflow during defrosting of the evaporator. It needs to be purged at the least or even cleaned thoroughly by removing the rear panel in the freezer to gain access.
Jun 11, 2014 | GE Profile : PSB42YSXSS 42" Built-in Side...
Whirlpool refrigerator with top freezer
If there is an ice maker in the freezer, look to see if the water is coming from there. If it is then replace the solenoid valve where the water comes into the back of the refrigerator.
Mar 05, 2014 | Whirlpool Freezers
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    Kenmore refrigerator with a bottom freezer leaks water on floor
    Hello Wayne,
    You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
    Good Luck
    Rich Lilja
    May 22, 2017 | Kenmore 13.7 cu. ft. / 388 liter Upright...
    There is a red glow from coil at bottom back of freezer that I can see through slats from inside. There is a sizzling water drip happening.
    there is an element in there for self-defrosting, if you have a self-defrosting model. It heats up like an oven element ( not nearly as hot) to get rid of frost build up.
    Nov 09, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
    Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
    When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
    Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
    I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
    Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
    Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
    Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
    Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
    Evaporator coil in freezer red hot and water dripping on it.
    This normal operation. Happens twice a day to defrost the freezer coils. Last about 20 minutes.
    May 02, 2009 | Kenmore Freezers
    Bottom freezer door dripping water on kitchen floor
    you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
    Jan 11, 2009 | Freezers
    Open Questions:
    Freezers Logo
    335 people viewed this question
    Top Maytag Freezers Experts
    John Tripp
    John Tripp
    christian nielsen
    john h
    Are you a Maytag Freezer Expert? Answer questions, earn points and help others
