Question about Mitsubishi WD-62528 62" LCD HDTV
I have a 62inch Mitsubishi wd-62528 when I plug it in the timer power light blinks green rapidly, it turns on once and not for long then shuts off with no light
  • 373 Answers
There should be a system restore button on the front that you can use a ball point pen to press. If you hear a difference if operation (like the fans starting up) then you have reset the system. However if it does not come on and light up the screen then you are likely to have a bad lamp. The lamp has an access door either on the front or the back of the set and is usually on the back. Take the lamp out and inspect it for breakage inside the bulb. Also look very carefully at the root of the filament in the center for bubble like of the glass. If so it is bad and needs replacing. The best place I have found to get a lamp w/housing is pureglare.com
Posted on May 24, 2011
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
My mitsubishi wd-62528 has a constant rapid green blinking light on timer and wont go out. had lamp replaced and reset but wont even come on.
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which contains the capacitors and the CD with instructions for the repair.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
It will not turn on
Try to unplug it for a minute, plug it again and see if the green light blinks for about 2 minutes. After that you will probably be able to turn it on. But the blinking light tells you that is time to replace the lamp.
Apr 25, 2009 | Mitsubishi WD-62528 62" LCD HDTV
Green timer light keeps blinking
Ross,
Please email me at experttv@comcast.net So i can help you.
Thank you,
Tim Nolan
Oct 14, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green timer light
check the number of blinks each blink means something
Apr 19, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-62528 62" LCD HDTV Logo
280 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
