Question about Saitek Cyborg Mouse
I have a wired mouse (R.A.T 7) that only movement doesn't work on only one computer. it has worked on the same motherboard for 4 months and the same hard-drive for 1.5 months just randomly stopped working while watching a YouTube video. Other USB and PS/2 mice work and i have uninstaller all drivers and reinstalled the right drivers for all Devices i even re-formatted my hard-drive to no avail. Another curious weird thing is i can leave it unplugged for a day and i will work for like 2 minutes. If anybody can solve this crazy riddle i would be Very happy as the mouse was $100 and i would rather not buy a different one.
  • Saitek Master
  • 3,828 Answers
If not usb ports or the plug itself
something failing /over heating internally in the mouse
is this the r.a.t.7
I have a wired mouse (R.A.T 7) that only movement - index-xfnla03ivjalhts5ighey2kg-5-0_1.jpg
Posted on Apr 11, 2017
3 Suggested Answers
SOURCE: Saitek Pro Flight yoke and quadrant stop working
Seems to me va power problem if you have a lot of other usb components running then you will need auxillary power, you have two choices really, the aformentioned USB card and fit to your MB
Or purchase teh Saitek power supply, and power the yoke direct.
I had the same problem and solved it by removing one of the usb devices form the yoke and putting it a usb slot on the rear of the computer. Mind you I have all the saitek panels as well.
hope this helps
Posted on Feb 17, 2010
mtadevic
  • 12 Answers
SOURCE: Cyborg Rat 7 mouse programming not working after windows 8 upgrade
Download the newest driver from the Cyborg Gaming website (http://www.cyborggaming.com/download.htm)
Posted on Nov 13, 2012
Testimonial: "Fixed, thought i already had the updated drivers/ software. but i was wrong."
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
The scroller on the top of the mouse does not scroll the page
Go to your control panel of the computer. Click on the tab "Change mouse whell settings" If you do nto find such tab then search for that tab by puttin word "mouse" in the search box.
There you can change scrolling setting. If it doesn't work then remove the wire of your mouse, shut down computer.
Insert the wire and restart computer. This will surely work. If not then contact I'll give you other remedy.
Sep 22, 2012 | HP Wireless Optical Mouse
1999 chevy k2500. changed spark plugs 4 times in 7 months. Runs good for a week then doesn't start. Changed spider, throttle body sensor. Still has no codes and once again won't start.
The next time it won't start ,pull a sparkplug wire and see if you're getting fire.Then we'll known whether its a ignition or fuel problem and go from there.
Jan 11, 2012 | 1999 Chevrolet K2500
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
I have had m-uvdel1 dell mouse for a while and over past few days it has stopped working,if i remove it and plug back in it helps for a while but then stops moving again, the weird thing is that the...
These are possible solutions for fixing a M-UVDEL1 USB mouse when the pointer gets stuck.
Computer: Dell Precision 380, OS: Windows XP Pro, SP3
Issue: The Mouse cursor/pointer frequently stops moving - gets "stuck" on the screen. The only way to get it back is to unplug the mouse, then replug it in, or to restart the computer. Uninstalling and reinstalling the mouse driver doesn't work.
Solution #1:
1. Take the mouse apart and clean the insides. Only one screw to remove on the bottom of the unit. The top opens a bit like a **** shell, then lifts off.
2. Make a diagram of the insides. There are 2 wire springs to be careful with, but the insides are simple and easy to clean.
3. Clean out any lint etc. inside the unit . Clean the roller with a Q-tip and rubbing alcohol if necessary.
4. Put everything back together.
Solution #2: Turn off power saving setting for the usb port used by the mouse.
1. Click on the green Windows "Start" button, then right click on "My Computer", and click on "Properties".
2. Click on the "Hardware" tab, then click on the "Device Manager" button.
3. Click on the "+" to expand "Universal Serial Bus Controllers".
4. Right click on each listing of the "USB Root Hub" and click on "Properties".
5. Click on the "Power" tab and find the one that lists your "HID-Compliant Mouse".
6. Click on the "Power Management" tab for that USB Root Hub, and deselect "Allow the computer to turn off this device to save power."
7. Click "OK", close the "Device Manager", then restart your computer to activate the setting.
Solution #3: Having read a number of forums, the actually problem may be due to a video driver issue.
1. Update your computer's video card driver.
Solution #4: The problem may be due to the Video Card Hardware acceleration setting.
1. On a blank space of your desktop, press the right mouse.
2. Select "properties". Click the "settings" tab.
3. At the bottom right of the little window, click "advanced". select the "performance" tab, or whichever tab includes the "Hardware acceleration" slider .
4. Slide the hardware acceleration slider down one notch. click "apply" then "ok".
hope this helps you
Sep 21, 2011 | Computers & Internet
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
My mouse is not working properly. My buttons work but my cursor doesn't move. The light goes on on the top but the light does not light on the bottom.
make sure the battery is good ((has full charge))also you make sure the usb device for the mouse is inserted correctly into the usb port (if applicable) or if its a lead
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable)) if this fails to fix the problem you could try it in safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click to update driver
if your computer came with a motherboard disk the driver could be on it
hope this helps
Aug 25, 2011 | Computers & Internet
Hi, I have USB keyboard and I installed PS/2 optic mouse to my PC. Mouse doesn't work .i have windows 7 ultimad 32 bit and MB DH55TC intel i am changin my optic mouse by roll mouse and again dont...
click start control panel view devices and printers you should see your mouse right click mouse you could open it and then select configuremy mouse or select settings then hardware make sure you have the correct mouse selected also right click on the mouse select properties to make sure you have the correct mouse right click on mouse you can troubleshoot this will activate the troubleshooting for you
hope this will help
Jul 23, 2011 | Computers & Internet
My SYLVANIA mouse model # SY-040R is not working. It worked for about a month and then stopped working. It is a usb retractable optical mouse. Please Help!
optical mice suffer issues like anything else, just because it has no moving parts, doesn't mean it's never going to quit.Try the obvious, move the mouse to another port on this machine or another machine, to confirm the malfunction, after this I would encourage you to take your newly confirmed mistake back to the retailer, as it is only 30 days old.
Jun 08, 2011 | Computers & Internet
My wired philips mini mouse was working one minute with no problems at all. then out of the blue it just quit working after watching a movie. i even tried hooking it up to 2 other PC's, but with the...
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
(if applicable)
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
May 10, 2011 | Computers & Internet
Saitek Cyborg Mouse Logo
97 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
Rob Emerson
Rob Emerson
juanmireles1
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
