Question about KitchenAid 450 Watts KM25G0XWH Stand Mixer
Im having problems with my Km25g 450 watts kithcenaid mixer. when i plug it in and turn it on it wont start at all. i checked the control board for burned out or worn out signs and did not find any. i know the motor itself is getting power put will not turn on. could it be the power cord? if not, what could i do?
SOURCE: Power On Problem
if you remove the top you will find a tiny fuse wrapped in a black band on the left side from the back. It connects two white wires which power the top-side motor brush. Most likely this needs to be replaced. You can check by bypassing it with roach clips or a copper wire. Unplug the machine first and be careful!
Posted on Feb 09, 2009
  • 45 Answers
SOURCE: Speed Control Unit test?
Take off the back cover. there should be 2 screws on top of a piece of metal, 1 on bottom. Start on turn. it should go about 1x a second. Turn the top scrws. Then go to 6. it should be 3x a second. Use the bottom screw to adjust that. When turn and 6 are corrrect, all other sppeeds are right. There might be something else in between the back cover and the 3 screw panel.
Posted on Aug 19, 2008
  • 43 Answers
SOURCE: mixer won't start
your problem sounds like the thermister is burnt out.
Posted on Dec 10, 2008
  • 4 Answers
Check to see if the contact points on the control board are working. Adjust the screws at the top of the control board until the contacts make contact. That should fix your problem.
Posted on Feb 20, 2009
ricardok45
  • 135 Answers
SOURCE: Kitchenaid KHM7T
Hi. Before you take your mixer apart, take a multimeter and test for continuity in the cord. Wiggle the ends of the cord while you're doing this in an attempt to make the cord fail. If it tests out OK, then you must get inside the mixer. If you have the ability to repair the mixer then do so, otherwise take it to a repair place for them to check it out.
Goto www.kitchenaid.com, enter your model # and search for the parts catalog for your mixer. Download the info. This will help you with the project
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Mar 28, 2009
What rpm is the 4th setting on the Kitchen Aid KM25G?
There is no internal adjustment for the speeds of your mixer and the Service Manual does not give any r.p.m. figures.
Apr 29, 2014 | KitchenAid Food Mixers
250 watts k45ss classic stand mixer doesn't run
My first guess would be the speed control plate. It has three screws in an upside down triangular shape. The two screws on top control and adjust speeds 1 thru 6, and often times just one screw being out a 16th of a turn will shut the mixer off completely. I would venture that when you were removing the two stud bolts you moved the adjustment screws on the speed control plate. Remember that even a slight movement can shut down your mixer, take a phillips screwdriver and turn the top left screw one quarter turn while the machine is on, it can start on you so don't be shocked and jump with a loaded screwdriver in your hand at the back of an electrical device, stay calm, if no start then try the left screw a quarter turn, if it does not start go to a half turn on each screw, if still no start turn thr screws back to the start place and try the bottom screw a quarter turn left and right, if you do not start by now, then something is wrong in another place, go back to the brushes and take them out and check how you put them in, these are the two most common problems with a no start mixer. If this does not fix your problem or get the mixer to start please come back here with more info. If you motor raced in the first place then I would suspect the phase control board, but when it came back to normal speed it leades me away from the phase board. When the phse control board goes out the mixer only works at high speed. So please let us know so that we can help further.
Mar 28, 2013 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer km25G
First what is the problem, second call KA customer service and ask for the commercial division, they are very helpful even if the machine is out of warranty, the commercial division caters to those machine but it has to be a commercial mixer as your is. Please get back to us as we can't help without knowing the problem
Feb 18, 2013 | KitchenAid 32685 Mixer
Model km25g
It sounds like your problem may be with the motor itself rather than the planetary, or with the board the motor switch is attached to. I think you need to test whether the motor is getting power when the switch is moved on. if it is, the motor may need to be replaced. If the switch is faulty, replace the board the switch is attached to.
Apr 29, 2012 | KitchenAid 32685 Mixer
I have a problem with my kitchenaid mixer (latest mixer) I changed the worm gear but I broke the control plate when I was replacing the worm gear So, I bought the part and changed it, but the mixer...
The Service Manual covering mixers with the control plate can be downloaded at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Things to consider:
The brushes have a chamfer on one edge and must be oriented so that the chamfer can pass a small stop in one corner of the brush sleeve.
Are all the wires to the control board connected correctly? The board is marked for the wires colors.
There are instructions in the manual for measuring the stator coils to find out if they are OK or not.
Checking out the armature is another whole thing and you can get information on-line about this (try searching "armature testing"). I really hope that you don't need to go this far.
Apr 16, 2017 | KitchenAid KITCHEN AID 5 Quart Artisan...
The latch/switch on the speed control board is stuck
You need to take the back cover off and then split the gear cases to find the mechanical reason why the lever is stuck. Take the motor off the pedestal, remove the planetary and undo the 9 screws that hold the bottom gearcase to the top housing. You will need to unplug the white and the black wires from one side of the speed control plate.
Jun 14, 2017 | KitchenAid K45SS Classic Stand Mixer
575 watt 6qt stand mixer. start out on low speed
Hi. If your mixer is still under warranty, call Kitchenaid, they are usually very good at replacing mixers under warranty.
If you're out of warranty, you'll need to order a new speed control board. Use the following link to download the parts catalog for your mixer.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212278.pdf
You can remove and replace this board yourself. Use the drawings to assist you with the project.
Mar 16, 2009 | KitchenAid KP26M1X Stand Mixer
Mixer switch is locked
If this is a 325 watt Artisan, there is no safety switch I know of unless its in the circuit board. Your mixer is broke.
Mar 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Power On Problem
Feb 13, 2009 | KitchenAid KP2671 Professional 6 Series...
Today mixer stopped while mixing.
OK, you mentioned everything except the brand. I found on some models of Sunbeam mixers that the speed governor would fail due to the control knob screw being loose.
On that particular model, the screw is behind a stick-on label in the center of the knob. Peel off the label and make sure the screw is tight.
If your mixer isn't a Sunbeam, please advise.
Mar 23, 2008 | KitchenAid KP26M1X Stand Mixer
KitchenAid 450 Watts KM25G0XWH Stand Mixer Logo
43 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
