Question about Breville Fresca BES860 2Cup Coffee Maker
All of a sudden the amount of coffee that is dispensed when I push the one cup or two up requirement is very random. Sometimes it simply does not stop pouring until I push the program button to stop and sometimes only a tiny bit of coffee comes through and I have to push the button say three times to get a reasonable ajmount of coffee. Is there a programme that I need to change. If so how do I do this as I have mislaid the instruction booklet. Purchased the machine in New Zealand on 16 August 2009. Thanks. Ann den Boer
    Novelist:
    Champion:
  • 219 Answers
Is your hopper locked correctly? If not it won't grind, won't grind correctly.
http://www.breville.com.au/media/mediaappearance/2098/BES860.pdf
Posted on Jul 29, 2011
Won't dispense all the coffee from the disc. Have to push button at least two times. Descaled Help
The discs tell the machine how much water to dispense through the disc. Some discs dispense a small amount for an Espresso, others give a larger drink. Normal cups will not fill, you need smaller coffee cups for most Tassimo drinks.
Check the packet to see how much it dispenses and check with a measurement jug to see if it is working properly, you may be surprised to find it is working fine.
Oct 03, 2014 | Bosch TASSIMO Coffee Makers & Espresso...
When I try to make a cup of coffee, only a small amount of water and coffee come out (like a shot of cappuccino) of the coffee dispenser while hot water is dispensed (simultaneously)...what could be the...
the flow pipe is blocked. you need a nylon thread to clean it out. you push it in and out a few time in the hole until it is clear. shold of come in the kit when bourght new
Sep 22, 2013 | Miele Coffee Makers & Espresso Machines
Why does ground flow from the top of brewer instead of coming through the dispenser?
Buy a new K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 11, 2013 | Keurig B70 Coffee Maker
Tried to set it up for the first time and the small cup & large cup both flashed ... I pushed the small cup and nothing happened so I turned off machine and unplugged and started again ... still same...
Call Keurig's customer service office. Their customer service rep will attempt to troubleshoot the problem by phone or replace the unit if unsuccessful.
Mar 02, 2011 | Keurig Elite B40 Coffee Maker
Coffee maker continues hot water flow even after making 2.5l of coffee. Randomly some days it makes the correct amount and other days it makes anywhere from 6oz to 30oz more causing the airpot to overflow...
definitely clean out the sprayhead. also, you may need to reset the dispense time on the board behind the front panel. the instructions are on the panel itself. make sure the switch is on "lock" after you are done.
Jan 27, 2011 | Bunn CDBCF 15 APS Coffee Maker
Machine dispenses twice amount water that is needed
Sure this wasn't finger trouble (pushing the 2-cups button)?
Oct 18, 2010 | Philips Senseo HD-7810 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
Breville Fresca BES860 2Cup Coffee Maker Logo
169 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
