Question about Haier CPN14XC9 Air Conditioner
1. High Pitch noise when fan on. Quite loud when fan on low setting 2. Air coming out smells quite strong - like mould. Model: CPN14XC9 What do I need to do? Thank you, Noel Ramsey.
Revs of the car go up but the speed doesn't increase at all,
The most obvious cause to this fault would be the clutch slipping then suddenly gripping and away it goes.Now are there any cluncking noises or is there any strong smell when this fault occurs.If there is a strong smell the chances are you will require a new clutch.If there is no smell it could be clutch release bearing,either way gearbox will have to come out.If there is any loud clunking noise,possible drive shaft,but this is unlikely. the problem needs to be diagnosed by a mechanic.Always ask for quotes 1st,If a clutch is required be prepaired for possible damaged flywheel.
Dec 11, 2013 | Cars & Trucks
Heater/air conditioning blower fan makes high pitch noise
Above the passenger's feet, 3 bolts to loosen and it comes right out...
Jun 05, 2013 | 1994 Mercury Capri
Loud high pitch feedback when audio plays
I can only think of tree possibilities:
1. Feedback created by a dry join on a circuit board
2. Feedback from a cooling fan that has malfunctioned
3. Feedback from a microphone that has malfunctioned
I would try disabling or fiddling with the settings on the microphone first, if that's the problem, I recommend you disable it and if you use a microphone regularly, the external alternative is quite a cheap way of replacing it, if its a cooling fan, and you have the knowledge to disassemble the laptop, try disconnecting it for a short time, if the feedback stops when you disconnect the fan, you need only replace the fan, if these two methods don't solve the problem, I would recommend you have a professional look at it for you, dry joins are quite hard to find and require special equipment to fix, and if that's not the issue, the professional should be able to find the problem anyway.
Good luck
Mar 13, 2013 | Acer Computers & Internet
When we first start the unit, it has gotten quite a loud whirring sound. We turn it off, then turn it back on and the noise virtually disappears - it's still there, but greatly diminished. I suspect...
that is the fan on start-up and the high pitch is the power supply components heating up make shure that the main fan is working always it will be slow at low volume if it quits you run the risk of the power supply failing
Jul 13, 2010 | Koss KS4192 System
When we start our dryer it makes a loud noise as if it struggles to get the drum moving. Once the dryer is moving it has no trouble moving, but every time we start it, the noise happens again even if i was...
Is this noise like a loud buzz or hum? If it is it may be the motor draging
and can't quite get going. bearing getting worn.
Also check drum rollers or glides and the idler pully one of them may
be dragging if they are you might put a little high temp oil on it.
Hope this helps..
Jan 25, 2010 | LG DLE2532W Electric Dryer
High pitched noise, engine shuts off at idle
You need fluid!! The high pitched noise yu hear is air in the hydraulic sections of the transmission. Top up the fluid then find out where the leak is
Good Luck
Mar 14, 2009 | 2000 Ford Escort
Loud Fan Noise
Review Date
Monday, 12th of September, 2005 --> What's Hot
User-friendly, built-in DVD player, high-throw ratio lens, fast power/cool down What's Not
Fan operation is quite audible, native resolution of just 480p The Final Word
A perfect coffee table companion Notes
# This product is no longer available directly from the manufacturer. It may be available in retail and distribution channels, or second hand. The price displayed is the price at review time and the last available recommended retail price.
The DV10 has a futuristic-looking outer casing and two internal speakers located behind a silver grille mesh at the rear. Heat is removed through its side ventilation and the internal fan has a noise level of 27dB, which is comparable to a loud computer and quite distracting when watching movies at low volume. At 368 x 117 x 273mm, the unit is small enough to permanently and inconspicuously reside on a coffee table.
this is from a review .
it sounds like that the fan needs to be cleaned the sound you hear is normal but if it sounds like its racein the moder might be on its way out if you have a can of air used to clean a key bored i would try to clean it out with that if not take it to a repair place to see if they could look at the moder
Jun 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
Panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
Apr 13, 2008 | Panasonic 50 in. Plasma TV
Haier CPN14XC9 Air Conditioner Logo
50 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
