Question about Steamist TC-135 Digital Temp 3/4" - 135-05.75 - Brushed Nickel
CAN NOT GET TO TURN ON THERMOSTAT IS NOT WORKING
Contact Steamist directly:
http://steamist.com/contact.htm
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 24, 2011
The ac will not work
Does the compressor turn on ? What thermostat ? This has no thermostat , are you hearing this noise under the hood , what you think is the thermostat turning on is the A/C compressor ! Does the blower motor work ! Does air blow out with heat on ?
Aug 19, 2015 | 2005 Pontiac G6
Heat won't turn on
Is the heat not turning on because the thermostat stop functioning? Or because there's a problem with the heater itself?
If the thermostat is not working, replace the batteries...if the problem is not with the thermostat, then the problem lies in your heating system.
Feb 28, 2015 | Honeywell TH4110D1007 Pro4000 Thermostat
Thermostat sometimes doesn't turn furnace on
Hello Kathy, The first thing that I would do is change the batteries in the thermostat. One or more may be weak and not turn on your furnace. I would put in Alkaline batteries. If that doesn't help, maybe a new thermostat is in order.
Feb 27, 2014 | Hunter 44550 Programmable Thermostat -...
I have the honeywell round thermostat #, CT87K. I am trying to wire it up to controla gas fireplace. I have two wires coming from the fireplace I have tried every combination of wires. it will turn the...
That Thermostat will not work on a gas fireplace. The voltage is all wrong. You need a thermostat that will work on millivolts generated by the thermopile on the pilot assembly of the fireplace burner. It will only turn on, because you opened the circuit. It will not turn it off automatically or at all, for that matter.
Better yet, why don't you purchase a Wireless Remote Control that has a thermostat built-in. It's a multifunction remote that will work up to 25 feet from the fireplace and comes with a wall hanger. The SkyTech # 3301TH, should work well for you. http://www.skytechsystem.com/
Feb 17, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
Refrigerator does not get cold. The freezer works fine, but the fridge only gets slightly cool.
normaly the fridge has its own thermostat to keep the tem right, if this thermostat has stoped working it will do one of two things,,, freez every thing up as it wont turn off the compressor or will just stop working as it wont turn on the compressor,,, try turning up the thermostat first,
Nov 19, 2009 | Hotpoint Refrigerators
The bottom heating element won't heat up
If the new element is good then the next thing to check is the selector knob (COOK/BROIL) and the thermostat for the oven.
To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
There is a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Oct 28, 2009 | Ovens
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
New programmable thermostats will not operate the furnace or air
did u turn the power off to unit before installing t-stats,if not then mabe blown low voltage fuse
Mar 28, 2009 | Honeywell Programmable Thermostat Heater
Will run and cool until the thermostat turns it off and will not start back up. Inside fan continues to run. Compressor is completely dead.
Dear jack289,
The thermostat is not working properly. When thermostat cutsoff the compressor Please turn the thermostat knob to higher setting if compressor starts working then please change the thermostat. The fan will run continuously since only the compressor is controlled by the themostat.
Regards,
ramesh22
Jun 25, 2008 | Intertherm Heating & Cooling
Steamist TC-135 Digital Temp 3/4" - 135-05.75 - Brushed Nickel Logo
528 people viewed this question
Top Steamist Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Steamist Hardware and Accessory Expert? Answer questions, earn points and help others
