Question about CyberPower 525SL (CPS525SL) UPS System
One side of my Cyberpower 525SL stopped working. When i press the red button the green light comes on, but goes off quickly accompanied by a beeping. The TV, dish, and vcr/dvd continues to work. Help with the problem; the only thing plugged into the dead side is TV ears.
  • droger68 May 26, 2011
    I suspect that the low battery is at fault and have ordered a new one from the site you recommended. We'll see when it gets here.
    Thanks. This has been so simple to do from my desk.
  • 794 Answers
Hi droger68,
The reason for the issue that you have right now with your Cyberpower 525SL is a bad battery. This means that some of the battery relay's component or relay has failed. You may contact the manufacturer if it's still under warranty. If not you may check this site they do have battery for your machine.
Hope this helps.
Thank you for using FixYa.
Posted on May 24, 2011
Cyberpower 1500 unstable output
You need an On-Line UPS, the one you have is a simpler version ...
Jul 08, 2014 | CyberPower 525SL (CPS525SL) UPS System
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
Quite awhile ago, one side of the unit went dead. Uesterday, after hearing a couple clicks, the unit will beep a few short beeps, then after a little bit, there will be a few short beeps again. I press the...
sounds like it is failing. When was the last time you tested its capacity? Test it to see how long the battery works. If it doesnt then get a new one or send it back where you got it.
Mar 09, 2010 | CyberPower 525SL (CPS525SL) UPS System
Wireing Fault Light is On
check the phase rotation of ups input, if it is a 3 phase input
Oct 14, 2009 | CyberPower 525SL (CPS525SL) UPS System
Battery side of UPS beeps on and off when turn on.
How old are your batteries? If they are over 3 years old it may be telling you that its time to get new batteries. You can check these using a voltmeter too to help determine if the batteries are the problem. You can find replacements at http://www.batteryinternational.com/ups-batteries.html
Jul 10, 2009 | CyberPower 525SL (CPS525SL) UPS System
Unit does not back-up (stay on-line at all) when power goes out.
If the battery is over 3 years old then it most likely needs to be replaced. Since it works fine except for when it is relying on power from the battery, then a new battery should make it just like new. http://www.batteryinternational.com/ups-batteries.html should have the battery you need. Hope that helps.
Apr 16, 2009 | CyberPower 525SL (CPS525SL) UPS System
Cbyer power 525Sl keeps turning off and on and beeps.
I have the exact same issue with my 525SL.
When you push in the red button - the green power light comes on for about 5 seconds = then the light goes out and the device plays a single long beep for about 5-8 seconds.
Given the dialogue here - I took out the battery and bough a brand new BB replacement battery and returned it into the unit as it should. The device continues to have the same behavior.
So it is NOT always a new battery that will fix the system.
Don't jump into spending $30.00 for a replacement.
Look into this further or you'll wind up wasting your money.
Oct 26, 2008 | CyberPower 525SL (CPS525SL) UPS System
(Cyberpower 525SL) not working properly
There is no other known cause of the cycling on/off behavior aside from
a bad battery. IT is possible that some component of the battery relay
or inverter has failed. If this is the case it would not be repairable
outside of warranty.
Regards,
Joel Gerlach
Cyber Power Systems (USA), Inc.
877-297-6937 x7917
Jul 03, 2008 | CyberPower 525SL (CPS525SL) UPS System
My computer won't boot and the CyberPower 825 AVR makes a continuous sound.
It sounds as though the UPS is not receiving power. Check that it's cable is properly plugged into the wall. Also verify that it's internal ground fault interrupter has not tripped, it's usually a little red button on the back of the unit, it should be pressed in and should stay that way, if it pops out then there is a problem with the ground of your electrical outlet. Also check that the breaker for that electrical has not tripped at your fuse box.
Since the UPS is not receiving power the batteries have discharged and that is why your computer cannot start, there is not enough juice from the UPS to boot it. That is also why it is making a noise as most UPS's sound an alarm to indicate that they are not connected to power.
There is a chance that the batteries in your UPS have gone bad or that something has become faulty in your UPS. Try plugging your computer and monitor directly to the wall bypassing the UPS to see if they work fine.
Jun 18, 2008 | CyberPower OfficePower 825AVR UPS System
CyberPower 525SL Failure
The erratic behavior and beeping could indicate that the Gel battery inside your UPS needs to be replaced, and is usually less expensive to replace than the entire UPS. You can remove the battery and contact a local or online source for a replacement. I replace mine through a local automotive battery supplier, and it' never cost me more than $20.00.
May 24, 2008 | CyberPower 525SL (CPS525SL) UPS System
CyberPower 525SL (CPS525SL) UPS System Logo
418 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
