Touch screen the board was taken from an identical machine that i have. the original problem was the board was damaged and some of the switches were not working. touch screen was working. the switches are now working fine but as i said no information coming to touchscreen
    Genius:
  • 2,028 Answers
Try swapping out the touch screens. It may be that they used different makes of touch screen in these models, and the board and screen are matched. This is the case with many laptop manufacturers. They use different screens in the same models, a cheapest bidder type thing I believe, so, if you switch boards, you have to switch screens or video cards in order to get them to work. Speaking of video cards, does this board have a removable video card or integrated. If it's removable, then you might swap them out if the screen change doesn't work. Try this and let me know.
Posted on Aug 15, 2008
6ya staff
SOURCE:
Brake light failure
Bad circuit board tail light asseblise connector pin to board poor connection or burned push in light bulb sockets
On my '93 Chevy PU the new ones went bad within months I repaired the original ones by soldering all connector pins to the board cleaned the sockets chipping out melted plastic been working for five years now.
Care must be taken to keep solder from preventing wire connector install while using enough that plugging it in will not break these delicate unions.
Required pulling them several times to Finnish repair successfully.
Very disappointed in replacement parts.
Apr 22, 2016 | 1987 Toyota Celica
Two different replacement LCD mainboards don't work
There are several versions of main boards for most models and all appear identical in everyway. But there are slight differences in critical areas. Chances are your not getting the correct version board. If you let me know the model number of the set I can most likely cross reference which version you have by the numbers off your original main board.
Oct 15, 2012 | Viore Televison & Video
I have a gt-b310, but the touchscreen has stopped working. Cant see any damage to the screen... Any ideas how to fix...
If the touch screen of your phone stops working. Since you have confirmed the fact that the screen is not damaged, then it is quite obvious that the problem is from the touch screen sensor board. If the sensor board is bad then it means the screen wont be responding to any for of touch.
The solution to the problem is for you to replace the sensor board. That should solve the problem for you. You will have to disassemble the phone and resit the flexi ribbon that connects the screen to the phones main board.
Thank you for using fixya.
Caseytech
Sep 02, 2011 | Cell Phones
Olympus FE-46 shows Card-cover open error. Cover is closed.
Hi, I have solved this problem in a Olympus Fe-20 camera. First of all, I will explain the facts of the problem. When closing the cover, inside the camera, there is a switch that get closed. This switch is like a door that opens or closes a electric contact. So when this switch is broken it does not join the contacts, so the camera thnks that the card cover is still open. Taking out some screws of the plastic tap of the touch screen, you will see, the touch screen fixed with a special conector. With a small screw driver take the black part up, and then you will manage to take out te touch screen. Then you have to take out the the board where the touch screen was fixed, taken out some screws , and disconneting the card from a similar conector than the one of the touch screen. So you can take out this board, and see that you have reach the main board of the camera. If you close the card cover, you can see in the main board the switch that opens/closes a contact due to the position of the cover. The switch has 4 welding points. You will have to take it out, by a tin solder. Then put a tin in the left down welding point and fix with a wire to the rigth up welding point. Fix the boarding card with its conector, fix the touch screen with its conector, and try to switch the camera on. If OK, fix everything up. If not, have a look at the contacts welded, that the problem is there. Hope to be helpfull.
Oct 26, 2010 | Olympus FE-46 Digital Camera
Samsung impression touch screen not work
some time it happens. touch phone screen has always two things first L.C.D means screen and touch panel which is the top of the L.C.D. if your phone touch is not working it could be the touch panel is gone damage. it happens when if you dropped your phone on floor and when its water or liquid damage. you need go to any samsung service centre or any phone repair shop
Dec 29, 2009 | Samsung SGH-A877 Impression Cell Phone
We have a I Mate Jas Jar has been off for a while and we have charged it but it seems to have a personality problem,,,, when you touch the command on screen, you need to touch three lines down,,,, and so...
First and foremost make sure that if you get through this problem you'll not ever place your phone in your tight jeans pocket when going out to the movies or elsewhere.Your phone needs to be placed in a pouch where it can be handheld or case carried to avoid pressure on the touch screen.
This problem is also common with my i-mate pda2k, what to do is turn it off, make a restart,after it comes on go to the screen allignment page, make the cursor move till it stops ..no matter how long it takes! cos it will definitely stop,take my word for it. Then test the accuracy of the touch screen till your o.k.
Sep 23, 2009 | Cell Phones
Sony hc-32 touch screen won't work
When touch switches become nonworking then mostly its cause of connecting flexible ribbon wires between LCD board and camcorder main board that got cracked so touch buttons signal does not go to camcorder system control. Need to replace that flexible wire by qualified camera tech.
Very rare cases I found touch buttons layer that is pasted and part of LCD becomes defective, do you see hard or deep scratch on LCD surface? if yes, then LCD screen will be replaced because touch button array is damaged.
Thanks.
Sep 16, 2009 | Sony DCR-HC32E DV Digital Camcorder
BENQ FP731s Monitor Problem white blank screen
You have a serious problem. ie. only the back light is working in your monitor. You might need to replace the TFT associate components.
May 06, 2007 | BenQ FP731 17" LCD Monitor
Open Questions:
Computers & Internet Logo
108 people viewed this question
Ekse
Marvin
Marvin
